Brushless dyno runs?
http://www.speedpassion.net/product.php?lang=&c=19
This is the only thing I have seen for doing a brushless motor analysis:
I have received that product from SP. Only thing is missing is the manual (I knew that when I placed the order), but now they have wiring information I'll give it a try
P.S....can you find out does this capable to do a PRINT OUT after you have hooked up to the computer via the USB port?
The only set back I see from a dyno test is with brushed motors we could align the hoods, zapp magnets, change brushes, etc..... What can you do if your brushless motor is a dud? There's nothing currently out for regular guys to zapp a rotor is there? I remember seeing a device that showed rotor strength but again....if the rotor is on the weak side then what???
2. new motor
Some guys claim if you hook a BL motor up to a CE turboDyno with the esc inline to the motor, and hit the throttle as you hit the start button you can dyno a BL motor. I have not seen this personally, but supposedly oval guys have tried it...
