Old 10-26-2008, 05:55 PM   #1
poochy's Avatar
Default tweak?
hi-can somebody please describe exactly what a tweak is and how to get rid of it?
poochy is offline   Reply With Quote
Old 10-26-2008, 06:06 PM   #2
Send a message via AIM to A-Ko
Tweak is usually when the suspension or chassis is unequal from one side to another and it causes the car to oversteer in one direction and understeer in another.
You need to make sure your suspension is equal on side to side. Like shock springs are compressed the same rate, droop screws the same length for starters before diagnosing the tweak. Once you get beyond that usually it is either the chassis top plate is loose or too tight or your shock oil is blown out one of your shocks from a hard crash or lots of barrel rolling on the track.
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 10-26-2008, 06:13 PM   #3
The way I define tweak is an imbalance in the chassis that causes the car not to handle properly. This is most obvious when the tweak is side to side and causes the car to be more agressive to one side then to the other. Causes of tweak can be uneven suspension, bind in the suspension, a warp or twist in the chassis, or uneven weight distribution.
Old 10-26-2008, 06:45 PM   #4
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
This is a pretty good tutorial...
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 45114 Today 03:32 PM
TC3 Forum Lowrider Electric On-Road 12151 10-07-2016 12:37 AM
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13402 09-27-2016 10:52 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Pocket Scales for Tweak??? royfan33 Nitro On-Road 9 08-07-2007 04:21 PM
Tweak and ride height question. RandomTask Electric On-Road 9 06-12-2006 09:27 AM
Tweaking a touring car? 429racer Electric On-Road 111 09-26-2004 06:24 PM
SEO by vBSEO 3.5.0
