Old 10-28-2011, 12:37 AM   #16
Originally Posted by Jstall7543 View Post
The sensors have nothing to do with the kv rating, they let the esc know the position of the rotor. As far as Know.
But changing the timing (at the endbell / sensor-port) can alter the Kv rating of a motor. More timing = more RPM = higher Kv, but less "pull". So higher Kv isn't always better. It can mean that the motor has more timing, and because of that maybe isn't a better motor - maybe even a worse motor.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 10-28-2011, 01:06 AM   #17
I have 3 10.5T motors from different manufacturers and the KV ratings on them are 3200, 3400 and 3600KV. All this really tells you is nothing. You can use all 3 in the 10.5T class and i guess thats all that matters, however, some make more torque others more rpm, and it becomes a horses for courses sort of thing to pick a motor for the track you are running on.
RogerDaShrubber is offline   Reply With Quote
Old 02-09-2012, 05:59 PM   #18
Default KV vs Turns
I think rc motors should be rated in kv and watts. That gives you information about gearing, motor performance, what amp rating your esc should be, and what C rating your batteries should be.
deza85 is offline   Reply With Quote
Old 11-19-2013, 10:53 PM   #19
I can tell you I run a stock AEsc10 on an indoor track that is small and tight so I was looking for a little more "quick zip". Being on a budget and not wanting to upgrade my esc I chose a stock AE reedy 4900KV. Motor. Same exact make and model of the stock 3300KV.
All I can say is this thing pulls the front wheels off the ground now!
Vetthed is offline   Reply With Quote
Old 11-20-2013, 02:59 AM   #20
howardcano's Avatar
Trader Rating: 35 (100%+)
The thread that wouldn't die!
Started in 2008.
Resuscitated in 2010.
And again in 2011.
Once more in 2012.
Fourth time in 2013.
There are plenty of good answers in the thread, and the information is still valid, and apparently still interesting!
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 11-20-2013, 11:53 PM   #21
wtcc's Avatar
So lets keep it alive for a little longer:
After reading everything it would mean the strongest 10.5t motor (no Corally red or GM equivalent) is the Team Orion Vortex VST 2 PRO 540 2P Stock (if the numbers are trustworthy):
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Tekno Conversions Thread teknorc Electric Off-Road 10239 10-09-2016 03:11 PM
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19920 04-03-2013 08:30 AM
kyosho electric offroad b-man777 Electric Off-Road 9014 12-22-2012 07:36 AM
1:8 EP BUGGY (CASTER) or ANY BRUSHLESS CONVERSION THREAD azmin Malaysian R/C Racers 336 12-14-2009 10:22 PM
kV ratings of the .5 brushless motors Sabin Electric On-Road 6 08-02-2008 05:33 AM
FS: Associated LRP Vector 6.5 Turn Brushless Motor and Sphere ESC Wolverini R/C Items: For Sale/Trade 8 05-04-2008 05:17 PM
SEO by vBSEO 3.5.0
