Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 08-08-2005, 05:31 AM   #2251
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Actually, a certain Jaco factory racer and I were discussing this two weekends ago, but I would like to point out that hte "wraps" do not have a stiffer inner foam. The inner foam is softer. That's why the tire has more forward bite- because the inner foam allows the tire to "lay down" more on acceleration- kinda the way a drag racing slick lays down and creates a much longer contact patch.
As for the material, I don't know all that much about foam, so it may actually be a firmer material with much larger cells, but I do know what I see and feel, and the inner foam compresses before the outer foam does.
BigDogRacing is offline   Reply With Quote
Old 08-08-2005, 05:59 AM   #2252
Josh Cyrul's Avatar
BigDog - The inner foam is around 40+ shore (when new) but the material gets softer with heat and use.
CEFX, T.O.P. Racing, Thunder Power, Shepherd Micro Racing, Novarossi, Jaco, Hacker, Ko Propo, Kimbrough, Faskolor, MuchMore & Reilly Paint
www.cefx.net - www.topracingusa.com - www.thunderpowerrc.com - www.team-shepherd.com - www.kopropo.com/america - www.novarossi.com
Josh Cyrul is offline   Reply With Quote
Old 08-08-2005, 02:34 PM   #2253
So it sounds like there will be a minimum dia. that we can run these tires to before we get into the core. I'm not sure I like that. Sounds like we will get less life from the tire and (probably?) pay more. Isn't that going in the wrong direction ?
jag88 is offline   Reply With Quote
Old 08-08-2005, 03:29 PM   #2254
sesimon's Avatar
Hi Josh,
I have a question I hope you can shed some light on. Here recently I have heard from several drivers that for carpet, to gain more traction you should stand the shocks up more and to get less traction you should lay them down. Everything I have ever heard before has been the opposite, so I'm a little confused which way I should go on shock placement for different conditions. Is what I'm hearing from those drivers correct or am I being mislead?
Thanks,
Scott
sesimon is offline   Reply With Quote
Old 09-27-2005, 08:02 PM   #2255
davepull's Avatar
hey josh did you change your front end design on your cars?
davepull is offline   Reply With Quote
Old 01-16-2006, 12:26 PM   #2256
Josh
I see you are having a birds oval warmup at your new track this weekend.
can you give us some details or pics of what the oval track specs are going to be.
Like runline? infield width etc
thanks
Eric Hutkay
erock1331 is offline   Reply With Quote
Old 01-16-2006, 01:56 PM   #2257
Originally Posted by erock1331
Josh
thanks
Eric Hutkay
Eric I answered your question on the other thread for CEFX Raceway and I will out them here as well.
The track is the same outer size as it was in Toledo with the same carpet.
Fri Jan 20 is practice 2pm-9pm $10.00
Sat Jan 21 is practice till 3:30pm 3 quals and mains start at 4pm
$15.00/first class and $5/each additional
3 people make a class and we will run whatever the guys want
Brian Anthony is offline   Reply With Quote
Old 01-16-2006, 05:49 PM   #2258
AdrianM's Avatar
This is true. The wraps are fastest when they are really small. After 1-2 runs they can peel. Honestly though regular foams are the same. There is a sweet spot for every track and the foams are fastest at that size. This is why pros at big races true tires so small and run a new set (scuffed in practice) for every qual and main.
At club races (lower traction) you can run them a little bigger and get a lot more life. The more serious the racers are in your area the smaller you have to run your tires.
Adrian Martinez
BMI Racing
bmiracing.com
DB12R NOW AVAILABLE!!
Forum Jump
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 08:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 08:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 06:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 02:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 04:46 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
