Old 09-21-2003, 12:39 PM   #1
Default Electronics Wiring Help Needed
I have a Bulldog RDC-15 Power supply. I am using it to power a Cobra comm lathe. I installed a Phanton 12v armature in the motor running the lathe. I want to be able to use a rotary knob of some sorts to vary the rpm's of the motor that runs the lathe. I'm not sure what I need here. I believe I need a voltage regulator and some sort of pot or rheostat. Help me out and go into as much detail as possible.
Thank you,
jcrouse is offline   Reply With Quote
Old 09-21-2003, 12:55 PM   #2
hyperformance's Avatar
Default bad news
i was looking to do the same, i run the cobra lathe as well with a mod motor for a slave (set at 0 timing). the trick is to use a potentiometer but the slave motor pulls such high amprege from the power supply that it's hard to find a pot that can handle it, when you do find one is $$$$$$$$$$. i heard you can use an adjustable power supply like the train guys do but all them i found were low amps two, plus about $60. i broke down and bought the vari-drive from corba
very sweet, worth every penny
hyperformance is offline   Reply With Quote
Old 09-21-2003, 02:57 PM   #3
fatdoggy's Avatar
R/C Tech Charter Subscriber
Just get a 55t lathe motor and run a 4 cell pack...
fatdoggy is offline   Reply With Quote
Old 09-21-2003, 09:26 PM   #4
use a 6-way switch and resistors, this will give you 6 speed settings
all available from radioshack
seriousre is offline   Reply With Quote
7.2 v KO servo wiring & PT wiring issues bshookup Radio and Electronics 2 06-12-2008 12:23 PM
Electronics advice needed for a musical instrument ClarkBattle Radio and Electronics 4 02-07-2008 04:35 PM
Car & Electronics needed!! xxxssportracer R/C Items: Wanted to Buy 9 11-05-2007 10:21 PM
wiring help? streetracer745 Electric On-Road 14 11-04-2006 09:52 PM
wiring, HELP! rice98w Electric On-Road 3 07-03-2003 04:12 AM
SEO by vBSEO 3.5.0
