64p steel pinions
Hello,
Where can i find 64p steel pinions? I fould only alloy :( |
just curious.....why do you need 64 pitch steel pinions?
Originally Posted by Tral
(Post 4895145)
Hello,
Originally Posted by sosidge
(Post 4895499)
The RW Racing pinions are made of steel.
I have a set of RW Racing steel pinions that are 4 years old and are perfect. I will never run another pinion. |
Robinson racing also make some
Why go steel? Better for the motor if it is alloy |
Originally Posted by Drifting101
(Post 4896015)
Why go steel? Better for the motor if it is alloy Theoretically the motor would work harder to spin up and slow down the mass of the steel pinion but the diffrence in weight is just a few grams. I challenge anyone to show me a measurable speed or lap time advantage due to light pinions. What you do gain is gears that last forever, mesh perfectly for years and thus never chew up spur gears. |
I like steel pinions for the durability as well...but living in a high humidity area I've had lots of problems with them rusting.
Originally Posted by InspGadgt
(Post 4896230)
Don't have a garage...keep everything in my bedroom...still rusts. Even had a stainless steel putter rust on me out here.
did 3-in-1 oil ever hurt to stop rust?
I was just thinking this weekend I could use a nice 64p pinion set along with harden steel bulkheads for my Xray. Aluminum just seems to cost more in the long run. It bends, breaks, wears, streches alot faster than steel. I used to have all aluminum screws in my cars, now I'm all stainless or alloy. I've only reached for a dremel once in the last year and it wasn't my car with the stipped screw. |
Where can we (Americans ;) ) buy the steel 64 pitch pinions you posted about? Can we get them through SchumacherUSA? Or do we need to order from abroad? Thanks!
Originally Posted by trailranger
(Post 4896895)
Originally Posted by andrewdoherty
(Post 4910801)
I don't know if they are available in USA, but you can order them here: http://www.rc-direct.co.uk Thank you for all reply. BTW, diameter 108 64p spur and 81 48p is the same, am i right? |
(Post 4911250)
I just bought a full set of the RW gears from here in the USA. It is an oval shop but they have them., i was there last week and they had a bunch..
http://www.lefthander-rc.com/catalog/index.php |
