Old 09-29-2008, 01:55 AM   #1
Default Lithium Polymer Battery 3700 and 4500mAH
We are well develop a new 3700, 4500 Li-Po battery for all 1/10 electric car, it specify design with durable graphite pattern plastic box.
Specification for 3700mAH (#BAT-L370025)
Discharge rate: 25C
Capacity: 3700mAH
Voltage: 7.4V
Length: 138.5mm
Width: 44.5mm
Height: 23.5mm
Net Weight: 210g
Specification for 4500mAH
Discharge rate: 30C
Capacity: 4500mAH
Voltage: 7.4V
Length: 138.5mm
Width: 44.5mm
Height: 23.5mm
Net Weight: 210g
Graphite Pattern Cover Case
We will include with one graphite pattern case for each individual battery pack, hard case helps protects the battery. battery pack are easily install, it suitable for all 1/10 electric onroad or offroad use. Both battery pack include connection cell, with tamiya plug and T-plug.
We are offer many advantages for Li-po battery:
- Hard graphite pattern case help to protect the battery
- easy install, suitable for 1/10 on-road or off-road
- Light weight than Sub-C battery cell
- No limit to the number of consecutive uses
- Longer lifespan
- include with connection wire with tamiya plug or T-plug
davy_ma0203 is offline   Reply With Quote
Old 09-29-2008, 06:23 AM   #2
Trader Rating: 32 (97%+)
What the duece? How much?
kikcaffine is offline   Reply With Quote
SEO by vBSEO 3.5.0
