Rubber on Carpet Questions
Hi, we are about to get our tourning car track started again (after a few seasons) and have had a few thoughts about running rubber instead of foam. The main reasons are attmepts at keeping the costs down for some of our newer/less experienced racers. Most of these guys just started and have only ran 1/8th offroad. So my questions are as follows
Do rubber tires have that much less traction?
Do rubber tires perform considerably better when new? ( we dont want poeple constantly buying new sets to stay competitive)
Is there a overall "go-to" tire we could possibly enforce as a spec tire?
I did a winter series last year on carpet, the spec tyre was the sorex 24. Six round series, I put over 2 hours of use in a set of them and I set TQ on the last round, which was the 3rd overall fastest time of the series.
I'd say that any rubber tyre is going to be a lot freindlier for everyone, you dont have to worry about rollout,changing droop/setup as the tyres wear, chunking tyres and the grip is fairly consistant throughout the age of the tyre.
With any new tyre there is an edge, but I wouldnt say there is a huge difference with them. I'm guessing a good racer could find .5 to 1 sec a lap with new tyres over worn ones that are useable (but that is just a guess).
I'm sure there are plenty of other tyres that could be used as a spec tyre, just telling you about my own experiences
hth.
hth.
you'd be surprised at how much grip rubber on carpet does have, but nowhere near what foams would give you.
i would say that for a stock racer, tyres are going to last anywhere up to 10wks. For modified touring, you're looking at 4-6wks.
Sorex are my brand of choice.
Sorex 20R gives best grip on the carpet we use (ozite).
Sorex 24R gives me good grip with longer tyre wear
Tamiya Type As give awesome wear, but not as much grip on carpet as I'd like. I'd stick to 540/Stock racing with these. Easily worth over 1000 laps (sorex for me are prob 500 laps).
</2cents>
</2cents>
We had been using the CS-27 until the supply dried up. Since then our spec tire has been the Jaco Green's.
Kinda what I've seen is there is an advantage to new tires but it doesn't last very long (just a few runs). Then the tires are pretty consistent for a long time.. depending on use of course.
And this kinda is restating what has already been said but rubber tires do have quite a bit of grip. You just have to drive the car differently. Your 1/8 guys will need to get adjusted to carpet but it will probably won't be too bad because they are used to driving with less traction anyway. Generally speaking our offroad guys were better rubber tire drivers than they were with foam.
If cost control is one of the reasons for a spec tire, you could consider the new Much More Sweep or Absolute series, downside of those though you will have to glue them, and they are around $30 a set.
Jaco's are also a good choice and have good wear, I have about 30+ runs on a set that I ran in Vegas and they are only a couple tenths slower then when they were new.
Sorex 28's are close to a RP30 for us here with similar lap times and wear.
True, the sweep tyres do seem reasonably well priced, but I have no experience with them. I cant imagine them wearing excessively on carpet though.
You'll actually find that with a new set of tires, your third or fourth run will be the fastest run and then the tires will be pretty consistant for the rest of thier usable life. I have a set of CS27s that have about 50-60 runs on them and they were faster after about 10 runs then they were new.
Talking about the sweeps... has anyone tried the low height tires on carpet???
On topic we ran CS-27's last winter, very good wear, and plenty traction. We'll be using Jaco's this year, green or blue haven't been out to test yet.
Tim
Tim
I have run them and they seem to have very good traction.
We wanted the Sweeps to cost less so we decided not to glue them. This is more cost effective, and if your club racing you can choose to change the inserts to sute the track condidtion. I love to experment with different inserts, and I know if I glued the tires it will be done right.
thanks for all the responses. I think we are looking for a premount spec tire so I'll look into the posted options.
Only other question is do rubber require any prep? For instance, heat or traction compound?
Rubber on carpet? That's just wrong....
