Old 09-26-2008, 03:15 PM   #16
Fear's Avatar
Send a message via AIM to Fear
Jaco Greens for me. Wonderful tire, fun asphalt tire as well, when Paragon'd.
Robitronic Avid
MambaMax 7700kV, LiPo, JR Z9100S
Associated RC8
RB S7, JR Z9100S/Z9100T(nuked, at JR for repair)/Futaba BLS-351
Futaba 4PK
Fear is offline   Reply With Quote
Old 09-26-2008, 06:42 PM   #17
chris moore's Avatar
Trader Rating: 85 (99%+)
Originally Posted by ryan sparks View Post
thanks for all the responses. I think we are looking for a premount spec tire so I'll look into the posted options.
Only other question is do rubber require any prep? For instance, heat or traction compound?
Jack is often the choice for carpet, mostly because it does'nt have the strong smell that paragon does. And that can be an advantage in an enclosed space.
Sponsered by:
CMDezigns Paint Works
chris moore is offline   Reply With Quote
Old 09-26-2008, 07:14 PM   #18
ottoman's Avatar
R/C Tech Charter Subscriber
Originally Posted by gijoe64 View Post
. I love to experment with different inserts
This is exactly what killed rubber racing last time. Guys started playing with different inserts, and rim stiffness and tire compounds and soon you had ten different tire setups in your pit box... big money. Instead of working on setups guys just swapped tires... didnt help them learn much.
Thats when foam took over in WI.... the theory was "all you need are Plaids and Purples" to run foam. Sounded good... they lasted a long time and with one compound it was cheap... in theory that is... didnt quite work out that way
Anyway to avoid the same problems most tracks pick one or two Premounts so you cant swap inserts etc. Cheaper in the long run.
Personally I like Jaco Blues for carpet... didnt much care for the Greens when we ran them.
ottoman is offline   Reply With Quote
Old 09-27-2008, 02:14 PM   #19
tc3team's Avatar
so is chunking tyres, changing gearing as foams wear and adjusting setup
Originally Posted by KE4PJO View Post
Rubber on carpet? That's just wrong....
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 09-27-2008, 05:26 PM   #20
decibels's Avatar
well i dont know about carpet. but on ashphalt sweeps understeer and have no grip unless the grip is there but they have a long wear range, last forever. havent tried the new low profile. absolutes are great cant get them anywhere anymore in australia anyway! sorex is a very stable tire, dont know about jaco greens but presume should be good from what ive heard. also there is a lot of new tires, look at price. ones i have seen be very quick and good price are top no mark, 32s should be good for you and dont change much after first run, stay very grippy. ive seen one racer who whenever bolts on xenons has unseen steering so they could be another choice. but i would say get a set of all and try between racers make a decision together and just run that one!!!
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13402 09-27-2016 10:52 AM
Team Corally RDX Touring Car Kenshin Electric On-Road 10561 11-20-2015 11:54 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 08:22 AM
TC5 Setup Help jmaster Electric On-Road 15 01-07-2009 12:28 PM
FS/FT CRC 3.2 Xray FK04 KO Helios module/receiver franzey R/C Items: For Sale/Trade 22 07-08-2007 12:00 PM
East Coast Shoot-Out Race Oct 16th JimmyMac Racing Forum 89 10-19-2004 09:41 PM
SEO by vBSEO 3.5.0
