WHAT TO USE ON BEARINGS
I,ve found that spraying carburator cleaner (1/1) on them is the easiest way to get em clean.... but havent tried ultrasonic things hehehe...... Tell me if it's worth buying one...
put your bearings in a jar and spray them out with motor spary, shake the jar (with the lid on), and relube i use a mix of stuff called prolong got it specailly from southa africa but it is basically a low friction lube and some zubak oil, wipe off the execess with a tissue and your done
sin lube is the best stuff i have used so far. i usually just soak and clean in simple green.....sits in the same cup as my comm
