Old 09-24-2008, 05:31 PM   #1
rc4fun's Avatar
Default I need ur help charger set up for lipo pack 4 cell 3300 mah 14.8 volts, ice charger
Hi' guys i need ur help im new bie with electric, i bought this lipo pack brand thunder power rc, 3300 mah, 14.8 volts, 4cells, 25c cont, 50c burst(82a/165a), im using ice charger with duratrax, i set the charger to 14.8volts, 3300mah, chrg 3.3mah and when i start charging the lipo pack d voltage already start with 15.63 and after 15 seconds still going up' is that supposed to be like that? i dont want to blew the lipo so i cut it off' any help i really appreciate it'
301raceway' onroad track "Eastcoast proud"
Blue Diamond on-road track
Hobbyworks Fairfax________Brooklyn hobbies
rc4fun is offline   Reply With Quote
Old 09-25-2008, 01:19 AM   #2
Super_Roo's Avatar
14.8 volts is the nominal voltage of the pack and is the correct setting for your charger, 3.7 volts per cell.
Your 4S lipo should charge to 4.2 volts per cell, so for a 4 cell pack it should charge to 16.8 volts.
Super_Roo is offline   Reply With Quote
Old 09-25-2008, 03:07 AM   #3
r0adrunn3r's Avatar
Send a message via MSN to r0adrunn3r
On the ICE charger, scroll to a new memory page.
The second line set: Li-Po 14.8V 3300mAh
chg current: 3.3A
All the other settings can stay as they are. It is ready to go.
When it charges the amps will slowly climb up to 3.3A (it will now sit at 3.3A) until the volts reach 16.8V. The charger will beep once when it reaches 16.8V. This is the end of the Constant Amps part of the LiPo charge cycle. The pack is 80% charged.
Then the Constant Volts part of the charge cycle starts. The charger will keep the volts at 16.8V but the amps will drop slowly down. The charger will beep again when the amps get down to 0.1A.
r0adrunn3r is offline   Reply With Quote
I need ur help charger set up for lipo pack 4 cell 3300 mah 14.8 volts, ice charger rc4fun Radio and Electronics 7 09-26-2008 03:52 AM
SEO by vBSEO 3.5.0
