Old 09-23-2008, 08:58 AM   #1
roadkill's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to roadkill
hello, what do you plp use to clean your bearings with, in an ultrasonic cleaner? (I E) simple green? thanx for any replys
need sponsor for upcoming dirt season.must be willing to throw lots of cash at off road cars.pm me and lets talk.
roadkill is offline   Reply With Quote
Old 09-23-2008, 04:42 PM   #2
Juanchoyo's Avatar
I,ve found that spraying carburator cleaner (1/1) on them is the easiest way to get em clean.... but havent tried ultrasonic things hehehe...... Tell me if it's worth buying one...
FoxRC Hobby Club
"Mas que un hobby, un estilo de vida. Algo que corre en los circuitos de mis venas"
.....ChOoJuAaAnNnn, Sebastian, Juancho... como quieran XD.... o Sebastian Oviedooo...
Juanchoyo is offline   Reply With Quote
Old 09-23-2008, 04:54 PM   #3
Don't use an ultrasonic cleaner for bearings, you will end up pitting the races that the bearings run on and wreck the bearing.
Spray motor cleaner, high pressure air and re-lube is what I do.
AE TC5R, GTB, SS13.5
RC_DAVE4 is offline   Reply With Quote
Old 09-24-2008, 04:34 AM   #4
Drifting101's Avatar
put your bearings in a jar and spray them out with motor spary, shake the jar (with the lid on), and relube i use a mix of stuff called prolong got it specailly from southa africa but it is basically a low friction lube and some zubak oil, wipe off the execess with a tissue and your done
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Drifting101 is offline   Reply With Quote
Old 09-24-2008, 07:14 AM   #5
Victory Side's Avatar
Send a message via Skype™ to Victory Side
Directly for Acer bearings. Buy RPM bearing blaster and spray with carb cleaner or electronic cleaner. let dry relube with SIN. (acer brand bearing oil). The bearing blaster works awesome. It is $9 for rpm, 9 for oil.
"There are only two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle." ~Albert Einstein
"Do you want to know who you are? Don't ask. Act! Action will delineate and define you.'
Victory Side is offline   Reply With Quote
Old 09-26-2008, 06:35 AM   #6
sin lube is the best stuff i have used so far. i usually just soak and clean in simple green.....sits in the same cup as my comm
tdog is offline   Reply With Quote
Team Magic G4 Motorman Nitro On-Road 11757 10-11-2016 09:24 PM
TC3 Forum Lowrider Electric On-Road 12151 10-07-2016 12:37 AM
MINI Z beebop Indonesia Racing 7570 08-19-2015 03:00 PM
Losi XXX-S TSR6 Electric On-Road 14329 01-26-2015 07:59 PM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
"Tamiya Class" racing...Help me choose - TA05 vs TA05R pgeldz Electric On-Road 84 08-09-2008 09:03 PM
Sydney Indoor raceway (S.I.R.) Dadaman Australian Racing 372 06-16-2008 02:39 AM
SEO by vBSEO 3.5.0
