Old 09-20-2008, 01:30 AM   #1
Default Novak GTB 4cell
Im running the 4cell 17.5 in my 1/12th and tonight it ran great till the last practice session when I no longer had throttle. I have no clue what happened everything is plugged in and its a full battery pack but the damn thing wont move, the steering servo still moves but thats it, the red led on the esc is solid and nothing happens when throttle or brake is applied, anyone have any clue what might be going on? Oh also i tried 3 different tx/rx combos to see if it was my radio.
bigko625 is offline   Reply With Quote
Old 09-20-2008, 01:50 AM   #2
are the lights working? if so it would be the motor at fault.
if not, try resetting the esc haven't been using in burshed mode with a brushless motor?
TraceRacing is offline   Reply With Quote
Old 09-20-2008, 11:57 AM   #3
well when i woke up this morning the motor was working but now the red , blue and amber lights are on but not blinking and the motor is running full power, i tried reprogramming the esc 3 times but still the same thing
Old 09-20-2008, 09:03 PM   #4
Jamie Hanson's Avatar
Trader Rating: 23 (100%+)
If I had to guess, it would be one of two things. Normally when this happens either the motor could be shorted. If you try and turn the motor, does it have a cogging effect, or does it feel like there is something rubbing? If there is a rubbing feel, then check the solder posts to make sure no two are touching each other, even if it is just a small little piece of solder.
The second thing might be the wire harness. Check the wires to make sure they are all intact, and check the harness to make sure all the prongs are correctly in place.
If this is a motor other than a Novak, I am guess the sensor wire connecting the motor to the speedo may be bad. I have seen it may times where people buy a sensor wire and it will not work. They buy a new one and all is fine.
Former RC fanatic just trying to keep up......
BSR Tires / Spektrum RC
Jamie Hanson is offline   Reply With Quote
Old 09-21-2008, 01:48 AM   #5
thats exactly whats happenin it sounds like something is rubbing ill check the harness and connections tomorrow and update the thread with whats going on
SMC 4000/25C/3.7V single cell Hardcase pack. Danny/SMC Electric On-Road 1022 03-10-2010 07:56 AM
GETTING OUT SALE alot of stuff pics inside!! LETSDRIVE!! R/C Items: For Sale/Trade 44 07-15-2009 08:37 AM
**AE 12R5** PartTime R/C Items: For Sale/Trade 6 06-21-2009 07:05 PM
Novak GTB 4cell and 13.5 motor F/s Fred Perkins R/C Items: For Sale/Trade 13 12-14-2007 05:52 PM
SEO by vBSEO 3.5.0
