Tamiya TB-02
#303
Re: TB02 SS Top View
Originally posted by izzyracer
see anything else not legal?
Car looks good! With all this talk of the SS arms I would be interested to see the difference in wheel base between your 04 and the TB02? Did you get he one way to work with that oh so flexy chassis
#304
Re: Re: TB02 SS Top View
Originally posted by madjack
Izzy,
Izzy,
It looks like it even has a shorter wheelbase than the TA04 when all the spacers are positioned apart and the same as using regular arms when the spacers are placed inward. You can probably fit a regular body if you go with this setup, if they allow it. I'm just basing my observation in relation to the Tamiya bodies.
#305
Re: Re: Re: TB02 SS Top View
Have not tried the one way yet! Something to do this Saturday.
I have been testing the one-way & 24' with little luck (hooks off power)Thinking that the 2 diff will be the way the run this "flexy flyer" chassis until a stiffer version is released...or it will end up as a GT3 car
#306
Originally posted by tamiyarcracer
Suradaj, the TB02 comes with a plastic spur gear adapter, you can also use the aluminum version from the EVO3. So Yes you can use any spur. The only small draw back is that the motor mount only allows for preset motor and gearing. IE the motor doesn't have infinate adjustability. the mounting screws go through holes not a slot.
DZ. I almost made a mistake when I built my TB02. make sure that the pin in the driveline in in the correct hole for the spur gear. It is pretty sloppy if it is in the wrong hole.
#307
Supersonic, never checked that out! thanks for letting us know. I've gotta check my box.
What do you type about that Gary!
Pugo1: Are you in PI? Check out my website as well as a link to TAOB. I think you'll find it interesting
Anyway, I raced my TB-02 (against SDs and Baracudas) here at the Fort last nite and landed 4th in the Bmain... Bad setup, bad driving skills , and its my first ever race on on-road We used stock motors only.
#308
currently stripping down the other Evo to build my 02... and it does say right on the box "compatible parts: TB Evolution III and TA04 option parts plus a wide range of racing tires"... not that i have a TCS race anywhere near me, but maybe someday i may travel again...
#309
I don't know how to post a picture so I will just attach it. Here are three pix of my TB02.
#310
2nd pic.
#313
Originally posted by tamiyadriver
does anyone run other types of spurs/pinions? im not fond of the stock gears, and the Evo spur adapter fits fine... just couldnt figure the spacing. i think 64p might be a mistake, seeing the flexiblity of the motor mount...
#314
I am going to get the alum motor mount motor holes milled out so I can adjust with at least 48 pitch. I agree with he 64 pitch. The chassis might flex to much for it. I hope TAMIYA comes out with hop up chassis~!
Does the EVO III alum mount fit? Need to try.
