Tamiya TB-02
#1966
Loose front dogbones
I am fairly new to RC cars - so be gentle. I recently picked up a TB-02 (Subaru Impreza) to setup as a rally car/parking lot basher (no racing). I had a lot of fun putting it together (much nicer than the TT-01's that I put together for my son's ). I currently have the suspension setup for max clearance (I am still debating on whether or not to dremel a little bit of the tub under the A arms for additional travel - the first cut is the hardest). As it stands right now - the dogbones are too loose. The front's pop out when I turn. I know that I can pick up a swing shaft, but I am afraid that I still may have problems. My question is, should I look to pickup a longer set of swing shafts than these?
http://www.rcmart.com/catalog/produc...ducts_id=16483
Will I have problems where the swing shaft meets the outdrive?
#1967
Make sure you have the foam spacers in the diff halves so the dogbones don't come out. If you do decide to get the universals....42mm is what you are looking for.
#1968
I don't recall putting any foam spacers in - I must have missed that step in my excitement. I'll try that first and see if it helps.
The stock dogbones are 42x6 mm correct? I can try to pick up some longer dogbones at the LHS if the spacers don't resolve the problem (keep in mind I have extra travel).
Thanks!
Thanks!
#1969
By the way - I just ordered an additional TB-02 for my son's birthday. Porsche Carrera GT for only $70.
#1970
Foam spacers should fix your problem...and 46mm is the correct length.
Just got back from TCS at Trackside in WI. Ran my TB-02 in GT-2 and finished 3rd in the B-main out of four mains. It was hooked up...but it's the last TCS it will be run in. Ran my friends TA-05 and it's much smoother and easier to drive for 13.5.
Also ran in the "rally" class....TQ'd and won the A-main! Great weekend overall.
#1971
hey dose the TT-01 and the TB-02 use the same center spur gear
and dose anyone know of any complany that make an something to use
change the spur to an different type so u can use normal pinon gears
#1972
#1974
They do not use the same spur gear...and I am not aware of any adapter to put a normal spur gear on a TB-02. Use Robinson Racing pinion gears(metric 48p) with your tamiya cars...last longer and runs smoother too.
#1975
#1976
My set-up for ozite carpet with medium grip:
-Plastic shocks--one hole pistons--80wt shock oil
-White springs up front with Blues in back
-Blue front swaybar
-one way up front...ball diff with evo III diff halves in back
-universals all around--TA-04 plastic suspension arms
-used the "C" block in the back from an evo III for toe-in
-camber set at -2...and toe set at a little toe out.
-stock droop settings...ride height at 5mm
-Blue front swaybar
#1977
If you guys really wanna race forget setting a TB-02 and buy a TA-05. Why do you think the TB-02 keeps going on sale for cheaper and cheaper!
#1978
#1979
TB02 Spool!
Hy there!
Last training session with my Evo5 i run a spool on carpet for the first time. For usual i run the oneway, but with it the car was a nearly perfect ride!!!
Now i plan to build also a spool instead of the oneway for my good old boys TB02 and TB02R.
I thought it this way.:
I take the kit diff (blak plastic), and build it the following way.
without the balls, diff plates, trust and norma lbearings, spring.
Instead the balls there come a sandpaper cuttet the same way as the plates, and the bronze bearings. when i screwed it together, i drill two 3mm holes through the outdrive, the ring gear and the secon outdrive (when i have luck, i drill trough a hole for the balls) and the fix it with a grub screw to secure it from open up.
The outdrives i tape with fiber glass tape to make them more durable. I think that will work.
What did you think, or have anyone a better (cheaper) way?
Greetings form Austria,
Blueman
Blueman
