Tamiya TB-02
#1651
TB Diffs
T02 = TB02R identical in all ways
TB02, TB02R, EvoIII Surikarn identical except Diff Joint
Standard diff joint T51042
short side has a moulded nut retainer, and that is why the diff spring can not go on the nut side with this diff joint.
Nut on short side (it fits in the mould)
Spring, thrust bearing on screw side.
EvoIII, EvoIV, EvoIVms T50992
uses a seperate nut retainer (A5 part evoIII surikarn, L10 part EvoIV, also same as TA05)
Long diff joint - spring with nut & retainer
Short diff joint - thrust bearing and screw.
One other difference I have found is the ring gear and bevel.
T50987 TB02, TB02R, F201, EvoIII surikarn
T51110 EvoIV and EvoIVms
I personally have not compared these items (but I will very soon and update all)
I use tamiyausa.com parts support system to compare items and research compatability. Another good web reference I use is tamiyaclub.com
(and of course rctech)
Links
tamiyausa parts support http://www.tamiyausa.com/product/rcpss.php
tamiya club www.tamiyaclub.com
just wish i could order in a dose of consistancy for my driving
Links
#1652
Hi, can anyone tell me what pinion would best suit a 55T spur for 540 silver can class?
I will be running on a fairly tight, ashphalt track.
sorry for yet another gearing question but i couldnt find an answer in previous posts (except switching to a 52T spur)
#1653
#1654
you'll have to use the hi speed spur from the f1 car and I for get the teeth and a 27 pininon i think, i'll have to check my car to see what is is. I have my tbo2 set up for tcs mabuchi racing. the tbo5's are about 1/2 second a lap faster.
#1655
#1656
thanks for the responses, guess i'll be looking for another spur.
#1657
Originally Posted by rayman
Anyone tried to install a 0.4 module spur from the the old tbevo 72T,88T? Which pinion would match? Still a lot being sold at the lhs.
#1658
Originally Posted by crunchracer
Did anyone get back to you on this? I am looking at trying the .4 myself
#1659
I am going to try some diff gears this weekend, I played around at www.gearchart.com to get some starting points for the sizes. I am shooting for @ 5.15 + or - , I am running a 52 26 right now, but trying to locate 26-27-28 pinion is next to impossible, so hopefully I can get the same numbers using the 0.4 pitch 72-35/36/37 just need to see what one will mesh up correctly. If I can't get the 0.4 to work, I will play around with the 48p and 64p.
#1660
if you are looking for metric pinion gears kawada makes a 26,27 and 28 tooth gears for the tb-02 the part numbers are pnb-626 pnb-627 pnb-628 good luck
#1662
#1663
if you want to use the 48 pitch gears you can use a 60 tooth spur and a 30,31 or 32 tooth pinion gears and they fit the b,c,d holes on the motor mount
#1664
#1665
Originally Posted by Difuser
Yeah but you are slower with the 02......
You gonna come up for TCS?
I don't know if I'm can make it.
