Old 03-23-2012, 11:52 AM   #676
wwddww34's Avatar
Trader Rating: 9 (91%+)
Check out this YouTube video of the World GT A1 Main Race that happened last Sunday during the 2012 ROAR Carpet Nationals in Dallas, Texas.
wwddww34 is offline   Reply With Quote
Old 03-28-2012, 10:26 AM   #677
wwddww34's Avatar
************** WORLD GT RACE SERIES ANNOUNCEMENT **************
Mike's Hobby Shop is hosting a series of 6 monthly indoor carpet races starting on April 29. Points will be awarded based on finishing order, attendance, and TQ of the day.
Read more about it by going here -->2012 Summer Carpet Shootout Series brought to you by Mikes Hobby Shop
This will be a great series for all World GT drivers.
Old 03-28-2012, 01:04 PM   #678
wingman2's Avatar
Hi guys, we run both 1c/10.5 cars with 2c/17.5 cars here in the UK. I have now run both combo's and my thoughts are that the 1c cars are quicker through the corners, whilst the 2c cars are faster down the straight! Here is a video from the Ardent GT10 winter series, which the latest round was held on Sunday (my car is the white and green car qual'd in 3rd place):
http://www.youtube.com/watch?feature...&v=uKuE7gN_ONM
Sponsored by CML Distribution - http://www.cmldistribution.co.uk
wingman2 is offline   Reply With Quote
Old 04-16-2012, 10:00 AM   #679
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Default Speedmerchant WGT help
I just picked up an old Speedmerchant WGT and I'm looking for a setup for it. I've noticed that the newer WGT cars all have the inline battery moved forward. The car I have is the first WGT version with the battery crosswise in the rear of the chassis.
Is there a significant advantage with the battery weight moved forward? If so, can it be compensated by shifting the elecyronics as forward as possible on my chassis?
One more thing, the car has the Speedmerchant multi-link front end. Can someone tell me how to check caster on it without having to use a setup station?
Any help would be appreciated.
YR4Dude is offline   Reply With Quote
Old 04-16-2012, 10:19 AM   #680
Trader Rating: 26 (100%+)
The new edition of the World GT does have the battery forward. The idea with the new cars is to have weight shifted forward, but at the same time as close to the center as possible. One trick Speedmerchant is doing is to mount the servo facing the back of the car in-line with the front arms, but that would be an option if you wanted to use the old-skool or new associated front-end.
To measure caster, just take the tires off and put on a flat board. Get a regular old camber guage and measure the angle of the hinge pin. Good place to start is 4 degrees castor, 1 degree camber and .20 front springs.
Pod droop is very important with the older car to get weight transfer to the front. Start with 2 degrees of pod droop and a red center spring.
The car should be very good.
Steve Boice
Sponsored by: Speedmerchant, Trinity/Revtech, Destiny, Protoform, Hobbywing USA, KO Propo, Ulti, Xenon, TQ Wire
Hyperform racing--In memory of Lino
Bigdaddyswank is offline   Reply With Quote
Old 04-16-2012, 11:00 AM   #681
YR4Dude's Avatar
Thanks. I'll try it stock first with the pod droop as you mentioned. If that doesn't work out I'll try the old-skool front end with the reversed servo.
Old 04-16-2012, 01:13 PM   #682
With the old school front end, .18 front springs worked the best. Also, 1.5 degrees of camber.
Steve Boice
Old 04-18-2012, 08:51 AM   #683
YR4Dude's Avatar
Default WGT tire and gearing setup
Bigdaddyswank - Thanks for your help with my specific chassis.
What tire diameter do I start with? Also what is the basic roll out to start with?
Old 04-18-2012, 10:08 AM   #684
wwddww34's Avatar
I am putting together a WGT car for some club racing. This is the first 1-cell setup I have ever put together. All that's left for me to do is pick an ESC to use. The motor I am using is a 13.5T Speed Passion Competition 3.0 1-Cell Version similar to the one in the pic below (only 13.5T instead of 3.5T).
I have a choice of 3 ESCs to install. They are (1) Castle Creations Mamba Max Pro 1-cell, (2) Tekin RS, and (3) Hobbywing Xerun 120A 1-Cell.
Of the 3 ESCs above, which one would you install in your WGT? Is one better than the others?
Old 04-18-2012, 11:14 AM   #685
YR4Dude's Avatar
Both the Mamba and the Tekin will either need an rx pack or booster because neither has BEC for 1s on board. Only the Hobbywing has a 1s BEC.
Old 04-18-2012, 11:18 AM   #686
2.1 fronts and 2.2 rears to start.
With blinky WGT at the Snowbirds, I ran 36/96 with a 2.0 rear. This is with a Tekin and a Revtech 13.5 with the timing turned upto almost the last notch.
Steve Boice
Old 04-21-2012, 04:25 AM   #687
Ed Delgado's Avatar
Would this body be legal for World GT? It is 200mm wide and would fit a World GT chassis like CRC or Speed Merchants well.
World GT Club Racing - To spec or not to spec is the question????-pict0026.jpg
Ed Delgado is offline   Reply With Quote
Old 04-21-2012, 04:31 AM   #688
wingracer's Avatar
Trader Rating: 23 (100%+)
My choice would be the Tekin. The latest software is truly excellent. You will need a pack or booster with it.
The Hobbywing sounds like a really good one too and doesn't need a pack or booster.
Never had or run against a mamba so can't help there.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 04-21-2012, 12:17 PM   #689
Norman2's Avatar
Ed, I believe WGT only uses bodies that are front engined like the
Protoform Sofia or Aston Martin DB9 or Corvette. Regards
Norman2
Norman2 is offline   Reply With Quote
Old 04-24-2012, 07:40 PM   #690
YR4Dude's Avatar
I have that exact body. Its made more for 1/10 200mm TC than for WGT. Its big and sits high. WGT bodies like the Parma DB9 and the Protoform Sofia are much lower in profile.
New JACO World GT spec tire Jack Rimer Electric On-Road 105 12-30-2011 03:25 PM
Peak Racing "World Spec" GP 3700 6 cell packs johnnyboydh R/C Items: For Sale/Trade 0 10-20-2006 07:08 AM
1/5 Club or Sports Spec Racing at Moorebank ElectricConvert Australian Racing 0 07-10-2006 04:40 AM
Sanyo HV 3000 World Spec Cheap!!!! TeamButter R/C Items: For Sale/Trade 5 12-26-2002 06:27 AM
