Old 09-25-2008, 07:15 AM   #46
beavis353's Avatar
Originally Posted by EAMotorsports View Post
It would be great if everyone could make a WGT tire using the same foam and hopefully BSR can in the near future. Then everyone could have their brand loyalty and all companies are involved.
There is at one other manufacture that is interested in making the spec type tire right now but does not want to do it in a Lilac compound.
EA
That is an excellent Post Eric,
For those tracks that have the rules established and the class running, our spec tire has been established as the Lilac. If another shore is provided as a handout, they will be junk once we get home. This entire class was created to eliviate some of the strain foam tire budgets have put on electric onroad racers.
Beavis
beavis353 is offline   Reply With Quote
Old 09-28-2008, 01:08 PM   #47
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
beavis makes a great point
trackdesigner71 is offline   Reply With Quote
Old 09-28-2008, 01:24 PM   #48
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
I read on the Grand Slam series thread that BSR has agreed to make them in Lilac (BSR Team Purple) compound as well for the class. Its the same shore rating as the Jaco lilac and will be on BSR's wheel.
So at least the racers have a choice of brand loyalty now.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 09-28-2008, 01:48 PM   #49
AdrianM's Avatar
EA
Can John do something to his rim like Jack did to make it so you can see its a spec tire? Make the rim white or gray or something.
Adrian Martinez
Old 09-28-2008, 01:56 PM   #50
Team EAM
I havent heard anything about that yet but I would figure that they would use a yellow stripe like they do on their other spec tires. I highly doubt they would want to have wheels made for it and probably dont have access to the same thing Jack does with the carbon fiber look.
To me a yellow stripe in the foam would serve the same purpose.
EA
Contact Us
Old 09-28-2008, 04:42 PM   #51
AdrianM's Avatar
EA
That might actually be better. Makes it harder for the guys that are thinking of gluing donughts of other compounds onto old spec carbon rims.
Adrian Martinez
Old 09-28-2008, 08:23 PM   #52
Still Bill's Avatar
Locally, in NorCal, we have a small group of racers using one of the two specs for World Pan Car GT. Everyone runs together.
#1 allows 10.5 BL with 4-cell NIMH
#2 allows 13.5 BL with 2-cell Lipo (hard case)
Seems to be popular; so, I am currently building a CRC X-10 per the lipo spec.
Could well work with 13.5 (NIMH) and 17.5 (lipo) too.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 09-29-2008, 06:04 AM   #53
Trader Rating: 37 (100%+)
Just a thought guys, why limit the body you can run? There are a lot of 200mm bodies you can run but your only limited to a couple (that you can get).
What deference does it make what body somebody runs? I personally would like to see more bodies out there. If you donít run the most aerodynamic body itís only hurting yourself. So to me, if you want to win you will run the corvetteÖ
If it doesnít matter to you if you win, run what ever you want.
And maybe donít open it up all the way but the bodies you can run are pretty limited right now.
Just my 2 cents.
Have fun
Bertetto is offline   Reply With Quote
Old 09-29-2008, 09:35 AM   #54
Grenade10's Avatar
Just my 2 cents.
Have fun
I FULLY AGREE - No Touring Car bodies, No GTP bodies .... which leaves alot of interesting cars to try.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 09-29-2008, 02:19 PM   #55
robk's Avatar
Trader Rating: 22 (100%+)
What deference does it make what body somebody runs? I personally would like to see more bodies out there. If you don’t run the most aerodynamic body it’s only hurting yourself. So to me, if you want to win you will run the corvette…
Apparently, nobody has tried the old HPI NSX. The body is realistic, but has the same general shape as all those "funny" Japanese touring bodies-little greenhouse, kinda blunt nosed, big wing.
http://www.hpiracing.com/products/en/7087/
Old 09-29-2008, 03:51 PM   #56
hanulec's Avatar
Trader Rating: 27 (100%+)
I believe Timmah from RCE said he was running the NSX body for a while -- I don't think he liked it that much. I'm going to try running the HPI Supra next (I've already run the HPI and Protoform Vettes).
Make sure everyone checks out the newly updated WorldGT rules -- the minimum roof height has been raised: http://worldgtrc.com/WGT_2008_Rules.pdf
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-29-2008, 03:53 PM   #57
Rob Burns's Avatar
I run an older HPI NSX on my 10L3T. I'm very happy with it and would recommend it to anyone. I'm pretty sure mine is 190mm. I din't know if they came in 200mm and they'd be fairly hard to find I imagine.
Rob Burns is offline   Reply With Quote
Old 09-29-2008, 04:14 PM   #58
gijoe64's Avatar
Trader Rating: 30 (100%+)
I say yes to GTP bodies as long as they are realistic, Protoform has and soon Parma will have GTP bodies for 200mm cars and look at some of the cool bodies comming out from Japan. I think most of the so called realistic bodies from HPI don't look that great, look at the IIC they had to slam the bodies just to make tech, so why not a GTP style body they look alot better than most.
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 09-29-2008, 04:20 PM   #59
RBLove's Avatar
Trader Rating: 72 (100%+)
LeMans style. The cars would be on rails.....
http://www.pro-lineracing.com/p-591-mulsanne-lmp.aspx
RBLove is offline   Reply With Quote
Old 09-29-2008, 04:25 PM   #60
tallyrc's Avatar
rob, i'm building up my 10l3t for worldGT as we speak and it is very easy to get it out to 200mm.. a single axle shim both sides in the rear or one on the left and a 1" right hub (the 10l3t's is 7/8) and then shim the fronts 5mm each side.. are you running on asphalt? i'd love to trade setups as we get these going...
once the class is established i'd love to see to classes of cars running on the same track just like sebring.. corvettes and bmw's letting gtp's pass.. too me that is fun..
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
New JACO World GT spec tire Jack Rimer Electric On-Road 105 12-30-2011 03:25 PM
Peak Racing "World Spec" GP 3700 6 cell packs johnnyboydh R/C Items: For Sale/Trade 0 10-20-2006 07:08 AM
1/5 Club or Sports Spec Racing at Moorebank ElectricConvert Australian Racing 0 07-10-2006 04:40 AM
Sanyo HV 3000 World Spec Cheap!!!! TeamButter R/C Items: For Sale/Trade 5 12-26-2002 06:27 AM
