Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 09-13-2008, 12:25 AM   #31
heretic's Avatar
Originally Posted by hanzo3 View Post
For lipos, what is the standard amperage we should charge at? I thought it was 1 amp? Can we ever go more than that?
It is 1C, not one amp. Empty 5000mAh packs= charge at 5 amps, empty 2400= 2,4 amps, etc.
For a nimh the charger keeps the amps constant , for lipo it keeps the voltage the same. So once the desired voltage is reached, the charger then starts decreasing the amps while charging. I hope this makes sense.
heretic is offline   Reply With Quote
Old 09-13-2008, 05:54 AM   #32
FOXY923's Avatar
It doesn't keep the voltage constant until the voltage reaches 8.4v.
LIPO's charge with the CC-CV method. This is Constant Current - Constant Voltage. The charger will charge a 5000mah lipo at 5amp until the pack is at 8.4v. Then the charger maintains the 8.4v while decreases the amps down to .1 (or somewhere around there).
So, Constant Current (5amps or 1C) is applied to the pack until 8.4v is reached, then the voltage remains Constant until the amps are down to zero (.1).
Paris Junction Hobbies ~ RROL.ca ~ Lou's Speedway
SCAR XRAY X10 ~ VTA XRAY T2
RACE 4FUN
FOXY923 is offline   Reply With Quote
Old 09-14-2008, 02:33 PM   #33
94eg!'s Avatar
Trader Rating: 16 (100%+)
So with theses hard-case lipos, how do you know if one of the cells has puffed up or not from sitting too long? This is my major concern about making the switch...
94eg! is offline   Reply With Quote
Old 09-14-2008, 02:37 PM   #34
Skitee's Avatar
With the Orion LiPo packs it's very easy to see if the cells have even puffed a little, the case is sealed and each half of the case is stuck to the cells. So any puffing and you should immediately see the difference.
Tamiya TA05 Ver.II R with Tamiya TBLE-01 & Tamiya TBLM-01 12T
Tamiya TA05MS with Tekin RS Pro & Team Orion 13.5
Tamiya TRF416 with LRP Sphere TC & Trinity Duo 4.5
Tamiya M03R with SJ FSSOP & Tamiya Sport Tuned
Skitee is offline   Reply With Quote
Forum Jump
Tamiya Championship Series Neil Rabara Racing Forum 12048 Today 07:57 AM
FWR 2009 Racing Season FWR Northwest Racers 5955 Yesterday 10:42 PM
KARZ Calgary xrayroooahhhh Canadian R/C Scene 4081 Yesterday 05:56 PM
HobbyTown USA V 1.0 pusher Racing Forum 16589 Yesterday 05:19 PM
2009 T.C.S. Three MSRA (Memphis, TN) 510 06-23-2009 02:14 PM
Team Orion 3200mAh Race Spec LiPo Nexus Racing Electric On-Road 1772 03-16-2008 08:52 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
