does any one know a place to order the 9x5x4 wheel bearings for the 415 and the ta05ms in quantity. I'd like to order about 30-40 of these bearings and cannot find a single place to order then in quantitiy.
rc-mushroom will let me buy them 4 at a time... but that's not gonna cut it.
Instead of going through the cost of stocking up on 950 bearings, another option is to upgrade to the TRF416/TA-05 IFS-R/TB-03 front and rear uprights which use a 1050 bearing which is a bit more reliable than the 950 bearings.
Tamiya TA05 Ver.II R with Tamiya TBLE-01 & Tamiya TBLM-01 12T
Tamiya TA05MS with Tekin RS Pro & Team Orion 13.5
Tamiya TRF416 with LRP Sphere TC & Trinity Duo 4.5
Tamiya M03R with SJ FSSOP & Tamiya Sport Tuned
Front knuckles (L/R)
Rear knuckles (L/R)
8 1050 bearings
Is this correct? I assume since these parts are used on the IFS that they fit the front hub carriers, and suspension arms/hinge pins perfectly? And also since these are 10x5x4 I can just re-use the same axels because the ID is the same right?
...And also since these are 10x5x4 I can just re-use the same axels because the ID is the same right?
The 416 and IFS-R don't use the same Evo-IV axles as the 950 bearing cars. You may have to switch them for the newer ones.
The 416 uses a 1.5mm spacer between the two bearings, while the 950 bearing cars use a 1.9mm spacer. Now either the 1050 bearings are wider, or the new axle is shorter...
