Tamiya TB02
Just announced by Tamiya
58310 1/10 Scale R/C 4WD Mercedes-Benz CLK-DTM For this new addition to the R/C Car Series, Tamiya introduces the TB-02. Based on TB Evolution III, the TB-02 chassis can be fitted with aluminum and carbon parts designed for the TB Evolution III. For the first model using this chassis, Tamiya has chosen the popular Mercedes-Benz CLK-DTM Team Vodafone AMG-Mercedes. Anyone have any photos? |
Where did you see this announcement?? I just looked at all the Tamiya sites and nothing is mentioned. Thanks
Its on the Orion web site with a load of hopups for it and the EVOIII
ta04
I hope this is a competitive chassis for TCS. It would be a nice change from the TA04.
:nod: :nod: |
Doesn't sound likely if it's based on the evo3!! That would mean carbon double deck chassis...04 is tub chassis...at least for GT2 class.
With the 12 gear options it should be tub based like the 01 was, you change the ratio with the different spur gears. With the lighter diffs etc it will help if they redid the susp geometry then it should be competitive. I think in the listing I saw a SSG upper deck which also points to a tub based car
