Anyone using a Futaba 3pm 2.4ghz with a Mamba MAX ESC?
Reason I ask is because the receiver in the 3pm 2.4ghz requires a 6V BEC according to the manual, and the Mamba MAX only puts out 5V. The reason I posted in this forum is becuase there are way more folks who view this one so I figured I'd ask here. My apologies in advance if I'm out of line in asking in thie section. v/r, - Paulie |
hi, I use the same "combo" : futaba 3pm 2.4ghz and mamba max........ it works perfectly !!
hope this will help you. cheers :sweat: |
Are you using a digital servo?
Also, are you using HRS mode on the radio, or PPM mode? - Paulie |
Originally Posted by pgeldz
(Post 4796831)
Also, are you using HRS mode on the radio, or PPM mode? - Paulie (HRS mode does not produce a significant increase in performance and may get trouble with lot of esc.... ;) cheers :nod: |
Thanks!
Anyone else using this combo with no problems? - Paulie |
