Old 08-25-2008, 07:59 AM   #1
jaminit's Avatar
Default Problems with xcelorin 9400 kv ESC BURNT!!
I recently bought a Losi Mini T. I ran it once and was so impressed I went out and invested like $500 in aluminum parts, a new Fatuba reciever and transmitter and of course a brushless system. I chose the Xcelorin 9400kv because I knew Losi made it and figured it would be very easy to install and use. I am running it on a 1900mah 2 cell Lipo batterey. I spent about 3 hours installing everything. Once installed I program the reciever with the esc. Hold button when powering up, throttle, reverse, both blue and green light on...great, power off, on. Steering works perfect. Hit throttle engine spins a little then dies. Turn off and on, steering still works but blue light is on and no throttle response. I Repeat the programming again and exact same thing engine spinns a little and stops, then no response. Repeat programming and poof smoke poors out of the little hole on the ESC. I contacted Losi and have to send unit back in. Pobably will take a couple of weeks to get the new unit, which is very frusturating. Has any one else had this problem???? This is my first experience with Electric and Losi and not a good start. Any advice or ideas??????Please help.
jaminit is offline   Reply With Quote
Old 08-25-2008, 09:03 AM   #2
Tech Legend
wyd's Avatar
Trader Rating: 47 (100%+)
Send a message via AIM to wyd
More than likely you just got a bad speedo. It happens from time to time. It does suck when it happens to you but Losi has sold thousands of these things so every now and then a bad one pops up.
For the most part nothing to worry about. Losi will get it fixed or more than likely send you a new one and you will be on your way to having some fun.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 08-25-2008, 09:12 AM   #3
jaminit's Avatar
Default Thanks...
Thanks. I hope so. I have been using gas for 15 years but am a true NEWBIE to Electric. What is the engine size with the 9400 kv package. Also another quick question. When you do the initial programming should the engine be plugged in or not? And does it matter if it is.
Old 08-25-2008, 10:49 AM   #4
Trader Rating: 56 (100%+)
Send a message via AIM to joey
the size of the motor is a 180 and its fine to program the esc with the motor plugged in, as the other guy said you just got a defective one it happens with electronics...
=Joe Wright=
joey is offline   Reply With Quote
Old 08-25-2008, 10:56 AM   #5
jaminit's Avatar
Default Thanks.
Hate to be a pain, but two more quick questions. One, what spur and pinion gears should I be running with this set up, and two I have been reading the post and am sooooo electric illiterate. Is there any website or books that explain all the electric terms you guys so easily use. Like figuring out what batterys to use, mah, lipo, engine info, and any other pertanent info I may need to excell in this area.
[COLOR="Red"]TA T4 w/Mamba Max 5400 KV:tire:[/COLOR]
[COLOR="Blue"]Losi Mini T/Slider Conversion w/Mamba Max 8000kv:eek:[/COLOR]
[COLOR="Indigo"]TA RC 18MT w/Mamba 8000kv:nod:
[COLOR="DarkRed"]RC 10l3 Oval [/COLOR]
[COLOR="DarkSlateGray"]TA T3 Stock[/COLOR]
Burnt ESC autostyle Electric On-Road 32 12-21-2007 01:48 PM
Help! Burnt TEKIN ESC! cheekeon Electric Off-Road 11 01-08-2007 01:18 PM
burnt up speedo thecrow2k Electric On-Road 1 01-09-2006 03:18 PM
Receiver burnt??? dct147 Nitro On-Road 7 08-21-2005 10:51 AM
Burnt? jwwu Electric On-Road 3 02-09-2003 08:51 PM
SEO by vBSEO 3.5.0
