Hot Bodies Cyclone 12
Is anyone running this car in the US. I've had my eye on this car for awhile now and just want some feed back and experinces with it
I got one in trade that I plan to sell and looked it over carefully. It has some nice features like the shock and the battery hold down. However it has some serious drawbacks too such as the bolt on non-diff side hub which makes it pretty much impossible to change the rear wheel track, the front of the t-plate bolts to the chassis so tweak screws are useless, and the rear pod area is crowded by the damper disks. I'm sure if built right and driven right the car can be competitive...there's just better designs out there IMO.
As for the rear axle... Just change it with an IRS or similar axle and that problem is solved also. You do want to change the front axles because the stock C12 front axles break instantly with little impact. With these changes the car is just as competitive as a Asso, CRC or Corally... It won the EC in the hands of Mark Rheinard and Andy Moore also races is pretty well IMO but I guess these guys also made these changes to the car...
Joost.
That is good to know...Like I said I got this in in trade so didn't get all the parts...didn't know about the optional pivot. Still changing out the rear axle adds another $50 to the price of the car to get it on par with others.
I have one that I recently bought from a friend of mine. The car is nice, it is a bit on the heavy side but it is a nice car. I don't use the battery straps but I think it would be nice to have. The front end is nice too, but my friend who sold it to me changed out the front in to the IRS lower front arms and caster blocks. The shock is also nice along with the rear pod which makes putting in a brushless setup easier. He also changed the rear axle to the IRS axle.....
The car is great and has done well in major races. For a T-plate car, I think it is the one to get.
Thanks for the replys guys keep'em coming
Hi guys is the rear pod seperate to the front chassis or is it one piece . In the mag i saw a article in it looked like it was one piece chassis .
No, the rear pod and the chassis are connected by a T-bar. The front end is really very nice from HB straight out of the box. But you can easily change it to a Associated type or new gen X CRC type front suspension or as said above, the IRS low profile front arms.
Another thing you DO want to change are the M4 bolts that hold down the front suspension. Metric screws have little thread to "bite" into the plastic parts. I changed them on my C12 with a set of imperial screws from Associated. Also, the small carbon plate where the disc-damping plates are between. You can put 2mm spacers underneath it so that this plate sits a little higher (also put a 2mm spacer under the center-post). This will create more motor space towards the front and will prevent the motor from touching the damper-disc.
The centershock is one of the best I have seen in 12th scale. It works like a charm.
All in all, the C12 is a very competitive car BUT you will need to make some changes to the car to make it even more competitive. Yes, that will set you back somewhere between $50 - $100 but then the car is long lasting race ready. If your race-demands are not so high you can drive it box-stock...
Joost.
Joost.
Kool thanks for the info .
this car is good but HPI no kit , have parts only !
