Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-29-2008, 06:20 PM   #181
Trader Rating: 14 (100%+)
Default ez
Got my ezrun Tekmodel 60A setup today and it is pretty impressive so far. I am running it in my Losi xxx-t with a Novak 10.5. I was kind of worried at first about the sensored to sensorless thing but it seems to be no problem at all. Setup was easy the only question I have is what should I gear it for off road racing. My spur gear is 86. What would be a good pinion to go with this. Right now I have a 20T on it.
ghj1997 is offline   Reply With Quote
Old 10-30-2008, 03:39 AM   #182
Drifting101's Avatar
a 9.5-9.0 FDR but if i know the internal gear ratio and i can work it out for you
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 11-01-2008, 11:47 AM   #183
guinnes.s's Avatar
Originally Posted by edwintklee View Post
guy,
i got a friend who has this problem, when the ezrun connected to spektrum rx, after less that 1 minute, the rx will reset itself, like in glitch situation,
but if those frequency rx no problem, but the spektrum rx connect to my ezrun no problem...
any ideas?
Having similar problem,
three time during a 4 races qualify the esc just stops for about 10 second and reset himself to default settings,and it need to reset the throttle and brakes to.
its getting on my nerves as it did cost me the A final .
im using a spektrum tx rx too,anyone else having same problem?
thanx
guinnes.s is offline   Reply With Quote
Old 11-01-2008, 05:07 PM   #184
Bikerbob's Avatar
Send a message via ICQ to Bikerbob Send a message via MSN to Bikerbob Send a message via Yahoo to Bikerbob
Well I was out at the track last night with my 35a 9t combo.
I was able to use the programming card and set all settings NP.
I went on the track and the power was great!!
I was able to do the triple (on a 14t double brushed.. no)
Now I am using the brushless and lipo now.. so I am getting a real 7.4v and a clean new motor.
I was practicing.. indoor facility on my 4wd belt MR4-BC. I was able to touch the motor after every run.. no problem.. warm.. but not HOT. I did one run for about 15mins.
For what I paid.. this combo has been great. I did end up breaking a fin off the fan, and the fan does spin sooo hard that there is a bit of a gyro effect.. I can FEEL the fan in the car.
Running the fan off the receiver might be a better idea..
Anyway.. I am giving this a 10 for value, a 9 for features, and a 8 for quality.. I am very happy.
James
Bikerbob is offline   Reply With Quote
Old 11-01-2008, 05:26 PM   #185
You can definatly feel the fan when the standing still......I have broken the fan and i bash in a rocky area........my switch atracts SO much dirt it is not funny
I agree with your ratings BikerBob
Schumacher
Old 11-01-2008, 05:45 PM   #186
Default gearing
ok guys off to the track on Sunday. How does this sound for gearing. I have a Losi xxx-t. I am going to use 86/23. Does this sound right. I have only ran it on the street and used a 20t pinion and it took a while to get up to speed but it was not even warm to the touch. So I am guessing I can go up a few teeth. Does this sound right.
Also I agree with the ratings on this esc. See how it holds up and then I will get another if it does.
Old 11-02-2008, 02:17 PM   #187
Default ez
Ok back from the track. Truck seemed a little slow. Started out with 23/86 and then went to 20/86 which seemed faster but still didn't seem super quick with a 10.5 in a losi xxx-t. What settings can I change to give it a little more torque. Overall very happy. Made the fastest single lap time I have ever done but I just feel there is more. My drive ratio is 2.56. Any help is appreciated.
Also i used 3300 nimh and tried a 5400 lipo and it seemed no faster.
Old 11-02-2008, 06:57 PM   #188
terryh1313's Avatar
Hello all, just got a speed passion 17.5, could i use the EZ-RUN esc with this motor
handle the business, before the busines handles you
terryh1313 is offline   Reply With Quote
Old 11-03-2008, 01:57 AM   #189
Grrr...the rain stopped for the first time today and i was so excited to check my speed with my new brushless in my truck and being still damp, no traction a 1:1 car comes flying out of a drive way i swerved and ran in to a concrete pole it was running for 37secs and was doin the 10t was doin 73kpm during impact......damage:
Rear chassis plate
Motor mount
Gear box
Inner rear susp. mount
Arm
Motor may be bent
Diff gear
Rear shock tower
so a 60-125 bux fix because of bordem
When new parts arrive i will test is full potential
Schumacher
Old 11-03-2008, 08:58 AM   #190
read this entire thread. Contemplating grabbing the 13T set up for my Slash....
I HAD a Novak SS5800, but,.well, we wont go into that. Not a Novak fan, but anyway, this looks like a decent set up.
My guess here is the 9T is just not the best application for off-road really.
Drifting101,...you stated do not use in a Slash, because it's 1/8th scale. Remember, the Slash is considerably LIGHTER than any 8th scale buggy or truck. Despite is 14" wheelbase, it is still weight-wise, the same as a Stampede, ect.
for $85 bucks , kind of hard to NOT try it out.
z-man280 is offline   Reply With Quote
Old 11-03-2008, 02:42 PM   #191
They are still heavier than a 1/10th, my 1/10th scale truck is pushing the motor a little hard any way
Schumacher
Old 11-03-2008, 03:24 PM   #192
not exactly-
heavier than a clodbuster? a F350? No. Although they might be a little heavier than a race truck, such as my T4, they still are not tanks by any means. They are also geared lower, numerically, with a 2.72 ratio, vs. the 2.6 which, helps compensate for weight. I still think the 13T is a better choice, so I will look that way anyway.
I will agree tho, as they are basically 1/8th scale. The current Toyota Tundra pro 4 truck runs a 116inch wheelbase, which, converted to 1/8th scale, makes for a 14.5 inch wheelbase. Darn close to the Slash for sure.
Old 11-09-2008, 07:54 AM   #193
joe of loath's Avatar
I'm going to be running a 60A 8.5t setup in my RWD TC (when I finish it lol). does a ratio of 5.5 sound right for a huge tarmac track?
HPI E-Firestorm - Traxxas Revo - Tamiya TA05 - Custom built TC
Pastafarian and proud.
a_main_attendee: don't be dissing ma spinnin doritos dawg!
joe of loath is offline   Reply With Quote
Old 11-09-2008, 07:06 PM   #194
dethklok151's Avatar
Trader Rating: 23 (100%+)
still running my 35amp with 3000 kv(13t)motor in my slash,now with 1/8 buggy tires,stock gearing.no problems.even on a muddy track,where the extra load might have been an issue,still no problems.havent even programmed it yet.just dont follow the all too common brushless trend of buying too fast of a motor(or high of a wind or kv rating).it is easier to make a slow motor faster than a fast motor slower imo.my buddy has the 9t in his slash and he is having problems with it,but i think it is the motor's bad.
it would be pretty hard to put down much more power in a slash anyway.play it safe and go with the 13t.
"hey buddy,ya gonna finish marshalling my car or just lay there and bleed?"
now with a kill-o-meter!
dethklok151 is offline   Reply With Quote
Old 11-09-2008, 08:45 PM   #195
nexxus's Avatar
Trader Rating: 36 (100%+)
I am not convinced you have read the whole thread as you state.
Because you would have seen my feedback on one of these in a Slash
and that irrespective of gearing, the motor can not handle running a slash for more than 4-5 minutes without cooking itself. We tried it in a mates slash to eliminate a binding drivetrain as a cause, same result.
Is this suitable for a Traxxas slash?
Short answer:
NO!
HPI - Baja 5B
HPI - Baja 5T
Traxxas - Mini Revo Brushless.
nexxus is offline   Reply With Quote
Forum Jump
Tamiya mini cooper sipaboy Electric On-Road 11805 Today 03:04 PM
Duratrax Evader cheech4 Electric Off-Road 911 Yesterday 07:04 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 01:50 PM
wich brushless system maylemay Electric Off-Road 38 06-09-2009 02:46 PM
Whats a cheap brushless system for a traxxas slash Leroy1234p Electric Off-Road 25 05-17-2009 07:07 PM
Xray copies academygaz Electric On-Road 151 11-03-2008 08:42 PM
Powered By: vBulletin v3.7.6
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
