SMC 5700mAh 25C Single Cell Lipo >
Old 09-10-2008, 06:11 PM
  #151
Danny - are you talking about a 7.4 two cell?
ElliotCanada is offline
Old 09-10-2008, 06:33 PM
  #152
Company Representative
Danny/SMC's Avatar
No it's 3.7v two cell pack as 7.4v is to fast for 12th scale.
Danny/SMC is offline
Old 09-10-2008, 06:37 PM
  #153
jag88's Avatar
Would a 3 cell pack be better for 1/10 pan ?
jag88 is offline
Old 09-10-2008, 06:43 PM
  #154
Danny/SMC's Avatar
This packs is primarily designed for 12th scale cars to have a solution for these cars to go Lipo. This pack can also be used in Oval where slower speeds are needed than 7.4v Lipo and 10th scale pancars can also use this packs. I expect the capacity to be in the 3800-4000 so that should be enough capacity for the 13.5-17.5 classes.
Old 09-11-2008, 11:59 PM
  #155
Radio Active's Avatar
Originally Posted by Rob Burns
I understand, that's why I said someone needs to make a kit so it will fit above the t-plate but below the shock. I'm in the process of switching back to a t-plate car as I prefer how they drive, having to run a link car just so I can run the battery would be annoying.
I wonder if the battery could fit up one side with electronics on the other side? Must need to find a way to keep it in the car I guess.
The old Tamiya C-Series cars used to run a T-bar that had a stick pack go over the top of it. The T-bar sat flush with the rest of the chassis and was mounted by 2 screws into the battery box. A similar configuration using ball-studs was used with the F103 cars. So you can design a t-bar set-up that will work without the need for a saddle pack layout.
Radio Active is offline
Old 09-12-2008, 12:12 AM
  #156
Trader Rating: 27 (100%+)
...but the design would have to work (well). Unlikely I think
convikt is offline
Old 09-12-2008, 02:52 AM
  #157
sportpak's Avatar
Trader Rating: 26 (100%+)
I'm still pretty stoked about this and look forward to more track testing results. I'm available next weekend for testing...
sportpak is offline
Old 09-12-2008, 12:10 PM
  #158
heretic's Avatar
My Corally sp12M works GREAT; thank you. With lipo also.
heretic is offline
Old 09-12-2008, 06:26 PM
  #159
Default 3.7
what about running a 11.1v paralell to make a 5.5v, which would be close to the 5 or + 5v that a 4600 4cell energy pack produces?
panchamp is offline
Old 09-12-2008, 06:40 PM
  #160
Regional Moderator
CarbonJoe's Avatar
Two 11.1V cells in parallel is still 11.1v, with twice the current capacity.
CarbonJoe is offline
Old 09-12-2008, 07:02 PM
  #161
Danny/SMC's Avatar
An 11.1v Lipo uses 3 Lipo cells in series of 3.7v
Lipo cells have 3.7v per cell.
Old 09-13-2008, 06:46 AM
  #162
PaintingRoly's Avatar
Trader Rating: 56 (100%+)
Danny this all sounds great. I belive this could be the perfect solution for 1/12 and the new "worlds GT" 1/10 class.
PaintingRoly is offline
Old 09-13-2008, 07:31 AM
  #163
RCSteve93's Avatar
Somebody didn't pay attention during physics class.
RCSteve93 is offline
Old 09-13-2008, 09:55 AM
  #164
tallyrc's Avatar
roly you interested in running the world gt class? i'm hoping we can get it going down here.. village would be a nice venue..
tallyrc is offline
Old 09-13-2008, 08:13 PM
  #165
Bigshades's Avatar
Trader Rating: 28 (97%+)
Bigshades is offline
