Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-29-2008, 03:28 PM   #1
Default A123 batteries
Hi
does anyone know about those batteries
Hypersonic™ 2300 6.6V
2300 mAh, 6.6V, Lithium Ion, 2S1P
Hypersonic™ 4600 6.6V
4600 mAh, 6.6V, Lithium Ion, 2S2P
NanophosphateŽ 2300 6.6V
2300mAh, 6.6V Lithium Ion 2S1P
and what do you think about them?
give some feedback
thanks
jopor is offline   Reply With Quote
Old 07-29-2008, 03:35 PM   #2
xrayeddy's Avatar
Trader Rating: 68 (100%+)
The new packs fit in most cars with no problems, but they're only 6.6v. It's not a problem if you race modified or bash.
I've run them in an converted xb8, savage, mf2 and in my xx4 with no problems other than the lack of punch you see with lipos and nimhs.
Team Terribles
xrayeddy is offline   Reply With Quote
Old 07-29-2008, 06:17 PM   #3
I've been using A123s for awhile now and they are ok for modified class, but I have had to modify every vehicle I ran them in so they fit.
feedback:
http://www.rctech.net/forum/showthread.php?t=148648&highlight=mattnin
http://myworld.ebay.com/arcadechamp/
convert stick radio to left thumb steering:
http://www.rctech.net/forum/showthread.php?t=161857
selling custom made tweak stations w/ 4 scales to measure crossweights pm for more info
http://www.rctech.net/forum/r-c-items-sale-trade/268784-price-check-custom-tweak-station.html
mattnin is offline   Reply With Quote
Old 07-29-2008, 07:44 PM   #4
jla8874's Avatar
Trader Rating: 23 (100%+)
I dont know if you can still get these, but a while back people were buying HUGE DeWalt batteries, 36 volts I think, on ebay for like 100 bucks and they a BUNCH of A123's inside them.
jla8874 is offline   Reply With Quote
Old 07-30-2008, 12:57 AM   #5
Born2Run's Avatar
Huge and expencive cells.I don't think they'll fit on a TC.
XRAY T1FK05/Hobbywing XERUN 120/Mamba Max /Dynamite C4 Big Stick 7700/MM 6900/
GM Evo 3 7T Delta/Vortex Orion 5.5/
Born2Run is offline   Reply With Quote
Old 07-30-2008, 02:04 AM   #6
I run them in my TRF416, good punc, top speed, mod motor, run time
Alf :-)
alf.skaar is offline   Reply With Quote
Old 07-30-2008, 02:08 AM   #7
Born2Run's Avatar
Alf :-)
Could you post some pics of your car with these batteries?
Old 07-30-2008, 03:24 AM   #8
Expensive? I don't think that 16$50 for a cell is too much if you need 2 or 4 of them (2s2p). That makes 66$ for the 2s2p 4600mAh 280g 6.6V nominal voltage pack. Advantages over LiPo are huge - very high charging current (can be charged in 15 minutes), hardcase, won't burst into flames, can handle low-voltage discarge (even to 0V and still ok). These are the "deWalt 36V" batteries or A123-s. They only have a bit worse Wh/kg ratio than LiPos, but better than NiMH and much more user friendly than both. Most newer chargers already know how to charge them.
http://media.hyperion.hk/dn/a123/123-brief.pdf
http://www.aircraft-world.com/shopdi...asp?search=yes
Even our local small battery-shop is selling them. In white "no-name" casing like the Hyperion one but without the logo. OEM from A123 I think.
lauri is offline   Reply With Quote
Old 07-30-2008, 04:27 AM   #9
Born2Run's Avatar
Maybe they are not so expencive but are huge.I would like to see how they fit on a TC.If some could post some pictures it would be very helpful.
Old 07-30-2008, 04:48 AM   #10
They are big, but they can be made to fit in a TC. Also, they are not expensive, they are way cheap. The pack I made cost about $40 and it is a 3400 mAh battery pack, has lots of punch, charges in about 15 minutes and of course, much safer than a LIPO.
I will take a picture later on today with it in my T2 007. I will even take a pic with my car on the balance blocks with the A123 mounted inside.
-Matt
feedback:
Old 07-30-2008, 04:50 AM   #11
fathead's Avatar
They fit easily check out this post from last year
http://www.rctech.net/forum/showthre...23#post3673656
Team Wave
LRP
TC5
www.TurboBricks.com
fathead is offline   Reply With Quote
Old 07-30-2008, 05:04 AM   #12
Born2Run's Avatar
TNX fathead.That's exactly i was looking for.Unfortunately the don't fit on my FK05 for a few mm or at least without modifications.
Old 07-30-2008, 06:05 AM   #13
jla8874's Avatar
What ever happened with that press release A123 put out talking about
"daisy-chaining" (2) A123 chargers together and charging a pack in like 5 minutes?
Old 07-30-2008, 10:12 AM   #14
As promised, here are a couple pictures of my A123 battery in my 007. I forgot that my speed control is in the shop, so I can't balance the car on the blocks for you. Also, I normally use a Tekin Redline 368 motor in there. I only threw in the Novak because I was troubleshooting my speed control.
feedback:
Old 07-30-2008, 03:45 PM   #15
When using on mod class would you use A123 or LIPO.
Which are the reasons for A123 and for LIPO.
Forum Jump
a123 Batteries in RC18? haulin79 Radio and Electronics 1 07-06-2008 10:26 PM
FS/FT a123 batteries and charger pilsner6981 R/C Items: For Sale/Trade 7 05-15-2008 10:47 PM
Hypersonic Turbo for A123 batteries James35 Radio and Electronics 0 10-30-2007 09:57 AM
A123 batteries? streetracer745 Electric Off-Road 40 10-26-2007 12:09 AM
A123 batteries for European people rcmelted Electric On-Road 2 05-06-2007 04:07 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
