Old 08-30-2009, 07:43 AM   #1021
redmike76's Avatar
Trader Rating: 36 (100%+)
Originally Posted by Rocky8333 View Post
Sounds promising. How would I go about doing a matte clearcoat? Again, sorry, all I have done is spray can bodies in the past .
Could try some Krylon matte finish even. I know it's not made for polycarbonate, but it would actually be adhearing to paint, not plastic. If you have some old beater bodies around, I'd suggest trying different things with them. You could paint the outside of one and bash it a bit to see how it holds up for you. You could also take Jackster's idea and sand a bit on one that's painted the normal way. Just my thoughts (I am by no means an expert).
redmike76 is offline   Reply With Quote
Old 08-30-2009, 10:04 PM   #1022
snoopyrc's Avatar
Alright, well, I just picked up a VTA car in the last few days, and now I gotta get a body I like. Unfortunetly, I can't get a 1973 Camaro body, but I figure I can throw this paint down on the '68 Camaro body from HPI. The question I have is, how would I go for a flat green color, instead of the shiny body I would get if I painted the car on the inside? I was thinking paint it on the outside, but I figure that will chip/ scrape off easily. Next thought was sanding the outside (paiting the inside) of the body with some fine grit sandpaper to take the shine off the body. Let me know what people think. Also, here's a pic of possibly my favorite car of all time, Hot Rod Magazine's "F-Bomb", and the paint scheme I'm going for.
Cheers, Dan.
The Pegasus is definitely the closest thing you will find to your F bomb shell. I would make sure you mask the windows on the outside as well and instead of sanding I think I would just try using a fine steel wool to rough up the shell and then I would try some of the Custom Laquer system paints on the outside. I would expect that to get you pretty close to what you are looking for. If you paint it on the inside as you normally would, you will get a glossy shine.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 08-30-2009, 10:21 PM   #1023
Jackster's Avatar
Trader Rating: 19 (100%+)
Here's my Pegasus '70 Mustang. I'm just waiting on decals, wheels and window trim.
Jackster is offline   Reply With Quote
Old 08-31-2009, 07:01 AM   #1024
MikeXray's Avatar
Trader Rating: 72 (100%+)
Cheers, Dan.
Rustoleum's flat protective enamel bonds to lexan very well if sprayed thin, the problem will be that I've only seen it in white and black. You could possibly spray the white on the outside then a flat green enamel paint and hope for the best, I have seen a matte clear at the store, but haven't tried it yet. Paint on the outside will rub off eventually, but your body is going to crack and need to be replaced eventually too, so it's kinda a toss up
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 08-31-2009, 09:42 AM   #1025
andyh's Avatar
Default ...
Tamiya PS-55 Flat Clear (Lexan specific, made to complete one of they're Porsche GT3 kits, the real car is Flat Black and Gold etc...) sprayed on the outside of the body. Make sure you don't spray over areas that you do not want to be matte. If the body still has the clear overspray film on it then you can cut out the areas you want to spray with the Flat paint. If not just make the windows...etc.
andyh is offline   Reply With Quote
Old 08-31-2009, 10:57 AM   #1026
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
I painted this Bolink Mustang with Flat Green Auto Primer from dupli-color. It works just fine and dont need to sand anything just spray it on the outside. It doesnt crack off or chip or anything....and its cheap for the size of the can compaired to other brands like Tamiya.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 08-31-2009, 11:04 AM   #1027
Trader Rating: 30 (94%+)
That actually is the look I was going for. I think I'll try it
Also, found that Parma SS body online, thought I wouldn't!
Rocky8333 is offline   Reply With Quote
Old 08-31-2009, 09:13 PM   #1028
Jackster's Avatar
they (duplicolor) also make a flexible bumper coating in about 5 different colors.
Old 09-01-2009, 09:41 AM   #1029
DARKSIDE's Avatar
Default CASHVILLE 24HR SCALE TRANS-AM ENDURO
here are some pics of the team cars from the enduro this past Saturday
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-p8292086.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-p8292087.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-p8292088.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-concourse_.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-vtadsc_0008.jpg
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
THUNDER JAM IX Snowbirds Warm-up
January 21, 2017 Thunder RC Raceway
http://events.rcsignup.com/events/displayEvent.cfm?id=5313
DARKSIDE is offline   Reply With Quote
Old 09-01-2009, 10:01 AM   #1030
MikeXray's Avatar
is that Vette body VTA legal?
Old 09-01-2009, 10:20 AM   #1031
DARKSIDE's Avatar
NO ITS NOT LEGAL ON THE USVTA RULES...but we allow most vintage muscle car bodies.
Old 09-01-2009, 11:10 AM   #1032
MikeXray's Avatar
the way it should be
Old 09-01-2009, 06:23 PM   #1033
snoopyrc's Avatar
Looks good though doesnt it. Well I think those black Vettes look awesome. No Im not asking for a rule change. I just like em thats all.
I see what you are getting at Andy. I saw an EVO on the groovydrift.com page and it was painted normal on the inside with a shade of green about like the F-bomb. Then it was sprayed on the outside with the Tamiya PS-55 Flat Clear and that does the trick. I definitely think thats the way to go for the matte paintjobs.
Old 09-01-2009, 09:40 PM   #1034
snoopyrc's Avatar
I found a pic of that EVO with the matte finish like the F-Bomb.
Old 09-01-2009, 09:46 PM   #1035
So thats painted normal on the inside and matte only on the outside? Sounds easier than masking the outside!
Vintage R/C Discussion/Pics/Selling/Wanted rcaddict Singapore R/C Racers 7291 01-09-2017 10:36 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Pics of Tony Neisinger's vintage RC12L paint jobs drbelleville Painting, Designs, Graphics and Photography 8 07-12-2008 04:09 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
SEO by vBSEO 3.5.0
