Old 11-20-2008, 04:09 PM   #571
jdob's Avatar
Originally Posted by speedsterblade View Post
Nice scheme jdob! Same colors I typcially use. Nice.
Originally Posted by dragracer72nova View Post
I like it!
Dave
Thanks guys! There are a couple of things I would like to have done differently, but I will just have to wait until I need to paint up another one...
jdob is offline   Reply With Quote
Old 11-20-2008, 05:41 PM   #572
dodgeboy's Avatar
Send a message via AIM to dodgeboy Send a message via Yahoo to dodgeboy
Originally Posted by Kregger View Post
Dodgeboy,
You do some really awsome work. I didn't realize that it was most of your bodies I was racing against at the HPI challenge in Cherry Hill, NJ.
Keep up the good work!
Thanks I am having a blast painting these old style bodies .
I had a few there.
It gave me a reason to go spend more money on racing books .
dodgeboy is offline   Reply With Quote
Old 11-21-2008, 10:45 AM   #573
CSeils's Avatar
Trader Rating: 48 (100%+)
Thanks to Jdob for the decal plug. Nice body! Looks good.
If anybody is interested, I just finished printing.
Exterior T/A Sponsor decal sheet - (9" x 6")
$7 - Shipping included.
PM me if interested.
also check out Internal Decals For Sale , for my other products.
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
customracingstickers@gmail.com - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline   Reply With Quote
Old 11-23-2008, 06:50 PM   #574
Super Moderator
Grizzbob's Avatar
Well, I think it's time we bump this thread, especially since I just finished my first VTA body(& it & the car TQ'd & won its first time out, too, ), so here's mine...
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 11-26-2008, 01:07 AM   #575
leerjet1's Avatar
Trader Rating: 85 (100%+)
Default My Camaro
Here is my 68 camaro. Tamiya gunmetal and orange. And smoke window tint.
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-vintage-camaro-.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-vintage-camaro-f.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-vintage-camaro-c.jpg
leerjet1 is offline   Reply With Quote
Old 11-26-2008, 05:12 AM   #576
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
you TQ'ed and won with a 'Cuda (this is loaded with sarcasm - because some people think there is only 1 good body for VTA and it ain't the 'Cuda lol)
I thought only Cameros won
Nice colors
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 11-26-2008, 09:51 AM   #577
BIG JIM WOODMAN's Avatar
Trader Rating: 69 (100%+)
Default cool!
Leerjet, This looks REAL. Nice job. I just started using Tamiya Paints myself. Nice colors.
Hi, my name is Jim and I am an RC addict!
Old Guys Rule!
Bumper tag anyone?
BIG JIM WOODMAN is offline   Reply With Quote
Old 11-30-2008, 12:15 PM   #578
weracerc's Avatar
Trader Rating: 36 (100%+)
Default Body saver - no more Cuda Crease
well maybe someone has already posted this idea i am not looing to find out - i found a way to keep my Cuda body from ending up witht e traditional Cuda Crease on the front fenders.......I used Dow spray foam insulation $5 at Lowes is enough to do probably 15 bodies - spray it in the nose of the car after all paint has been applied and cured.....allow the foam to expand and dry/cure 4 hours or so then trim it out to fit you front bumper (i use the Parma wide bumper TC4) - the whole front end is supported and re-inforced with foam - much like modern cars foam support that is under the plastic bumper covers on 1:1 scale cars.......cheap easy fix to the front end smushed noses of the Cudas try it on any car it should keep the front end from being damaged...it does not weight the car down either.
weracerc is offline   Reply With Quote
Old 11-30-2008, 02:50 PM   #579
This sounds like it should work. Let us know how it works on the track, I'm thinking it might pop out of place in a hard hit. How about crumbling apart a falling out on the track?
Old Guys Rule!
Bumper tag anyone?
Old 11-30-2008, 04:55 PM   #580
weracerc's Avatar
it adheres very well to the cured pianted surface and is not brittle very flexible - no crumble factor (not like styrofoam) - once it dries you cut it with an exacto or other serrated edge blade to fit tight to your chassis/bumper/etc.......cant beleive i did not think of this sooner - would work on any body that is prone to front or rear cave in factor - the Cuda is very thin up front and does not take a hit even a small hit well......I used thicker lexan and pop rivets to mend the broken split areas then i used shoe goo to help bond it then i sprayed the foam insulation in - i took my other Cuda that has not seen any track time and filled it up and trimmed it out i dont expect to have any issues with the body that has never been crushed or split the repaired body should be good for at least 4 more race weekends even more if i can stay off the walls and comp! ha..actually if you can drive you dont need to do this but if you are like me and hit everything in site then this will help preserve that $50 body.....i cant afford to buy bodies every other race.
Old 11-30-2008, 06:54 PM   #581
Gyro's Avatar
Smile SWEET!!!!
I just bought the Shelby Body as I have now reduced 4 Cuda bodies into non practice worthy split up pieces of junk. I have used so much shoo goo that my nose may never recover. I will pick up a new Cuda body this week and try this out myself as well. I am actually excited about this as the Cuda is and always will be my favorite car of all time. As a Mopar nut, I would hate to give up on this body, but destroying a body every month is just too costly, and time consuming. Thanks for this tip!!!
Gyro
The Green Cuda Board Tagger :tire:
Gyro is offline   Reply With Quote
Old 12-01-2008, 09:35 AM   #582
dodgeboy's Avatar
Javelin knock off
What do you think?
Old 12-01-2008, 10:10 AM   #583
Joe R.'s Avatar
I think that is the best knock off Javelin yet!
Awesome.
Mustang GT-350H VTA car.
http://www.rctech.net/forum/electric-road/233734-u-s-vintage-trans-am-pics-paint-discussion-only-20.html#post5121988
Want to convert your Bolink Legend to mount a standard 1/10 scale body? PM me for details.
Joe R. is offline   Reply With Quote
Old 12-01-2008, 11:02 AM   #584
IndyRC_Racer's Avatar
Good job on the Camalin or should we call it a Javaro?
IndyRC_Racer is offline   Reply With Quote
Old 12-01-2008, 11:31 AM   #585
k_bojar's Avatar
Awesome.
Originally Posted by dodgeboy View Post
Javelin knock off
What do you think?
HOT DAMN!!!!
sweet as ever - and its all MINE MINE MINE MINE
Vintage R/C Discussion/Pics/Selling/Wanted rcaddict Singapore R/C Racers 7291 01-09-2017 10:36 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Pics of Tony Neisinger's vintage RC12L paint jobs drbelleville Painting, Designs, Graphics and Photography 8 07-12-2008 04:09 AM
SEO by vBSEO 3.5.0
