Old 04-04-2014, 10:53 AM   #4726
IndyHobbies.com's Avatar
Originally Posted by ASM View Post
Scott - fantastic work on the front and rear of this body. All I can say is WOW!!
Thanks ASM! We were going to try to lightly spray some side scallops to match the Charger, but if it didn't look right, it would spoil it. So, we held off. He's thinking about a second one so that he can keep one nice body for display.
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 04-04-2014, 12:51 PM   #4727
snoopyrc's Avatar
I was with you until you said 1/8th.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 04-04-2014, 01:05 PM   #4728
kwkride's Avatar
Me to . . . . .
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 04-05-2014, 04:28 PM   #4729
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
Your work has insipired me to go ahead and start what I believe will be a pretty unique and period correct scheme for my Southern Nats body this year. I kinda tied in paint scheme that was used back in the early 70's at my hometown 1/8 mile oval track. Got paintinpete on the job
Thanks for the inspiration!!
Scott Meeks
2016 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 04-06-2014, 04:13 PM   #4730
Finished this one today for a VTA racer. He wanted a "YENKO Camaro" which was a super high powered version of the Camaro you could buy. Some of you may remember from back in the day. If you google "Yenko Camaro", you will learn about the history. Real ones sell for a pretty penny now!
He didn't send along the decals or the rear spoiler. He said he didnt run the spoiler. I custom mixed the paint to match that era. I think I'm pretty close. Rockstar helped me with masks (thanks!).
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-yenkocamaro01.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-yenkocamaro02.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-yenkocamaro03.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-yenkocamaro04.jpg
USVTA #144
Old 04-06-2014, 05:45 PM   #4731
18to88's Avatar
Yes sir that one is mine. I did not see any Yenko's and I know that they never raced in VTA. But they are so much a part of that era, so I thought why not......
I think Scott did a fantastic job!
18to88 is offline   Reply With Quote
Old 04-06-2014, 07:54 PM   #4732
NutDriver's Avatar
Trader Rating: 14 (100%+)
Here is a question for the painters in the group. I am wanting to do a matte black paint scheme, but I want to paint the body on the inside. How do I make the finish matte?
(Yes, I know that painting it on the outside will basically do that, but that's not what I want to do)
Scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is online now   Reply With Quote
Old 04-06-2014, 08:29 PM   #4733
Scott
color on the inside; flat clear the outside.
freebird is offline   Reply With Quote
Old 04-06-2014, 08:49 PM   #4734
snoopyrc's Avatar
Yep. Tamiya has a clear frost that works well. If you use factory decals then you should decide if you want them to be matte finish or not. If you do then paint them as well.
Old 04-07-2014, 07:12 AM   #4735
Tommy R's Avatar
Trader Rating: 19 (100%+)
Guys, he said he wants the paint on the inside. Honestly, I'm not sure what you could do to achieve a flat or satin finish on the outside with only paint on the inside. Maybe lightly media blast the painted sections on the inside prior to paint? I really don't know if you have many options?
Tommy R is offline   Reply With Quote
Old 04-07-2014, 07:46 AM   #4736
NutDriver's Avatar
Thank you for the responses. While TommyR is correct as to what I posted, I did get the answer that I was looking for. Thank you all. ☺
USVTA member #111
Old 04-07-2014, 08:56 AM   #4737
Aaron P's Avatar
You can also scuff up the areas you want to look flat with Scotchbrite or a lite sand paper. Then, flat black spray paint. This gives a decent flat look, but for best results, do this for both the inside AND outside. The inside coat hides the scratches that happen on the outside.
Aaron P is offline   Reply With Quote
Old 04-07-2014, 01:07 PM   #4738
Maybe a company that has a corn blaster. They use ground corn instead of sand to blast wood, jewelry and other delicate surfaces.
I have seen a method using a chemical that turned the glossy Lexan surface flat. I'm thinking it was something like finger nail polish remover? Sprayed on? Don't take my word for it. Hopefully someone else will remember. Basically, it melts the surface and then evaporates.
I know I've tried to use CA remover on Lexan before and it reacted with the surface. You'd have to spray it and hope you got an even reaction.
USVTA #144
Old 04-07-2014, 01:09 PM   #4739
Tommy R's Avatar
Good point, Indy! I once used Goo Gone to remove adhesive residue from a lexan body and it left the surface very hazy. Might be tough to get a consistent finish, however.
Old 04-07-2014, 01:43 PM   #4740
IndyRC_Racer's Avatar
IN MY EXPERIENCE...
Regular Goo Gone that comes in a plastic bottle does NOT affect lexan bodies.
On the other hand...
GOOF OFF that comes in a metal can DOES react negatively with lexan bodies.
I made the mistake of trying to clean off some sticker residue with Goof Off in a window area and it fogged up the lexan.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Vintage R/C Discussion/Pics/Selling/Wanted rcaddict Singapore R/C Racers 7291 01-09-2017 10:36 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Pics of Tony Neisinger's vintage RC12L paint jobs drbelleville Painting, Designs, Graphics and Photography 8 07-12-2008 04:09 AM
SEO by vBSEO 3.5.0
