Old 01-30-2013, 08:05 AM   #3601
gijoe64's Avatar
Trader Rating: 26 (100%+)
Check out the new Vaterra 1969 Camaro, and no this body is not 200mm
http://www.youtube.com/watch?v=Fup5F_VprB4
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 01-30-2013, 08:33 AM   #3602
will it fit a USVTA chassis ??
Rojna is offline   Reply With Quote
Old 01-30-2013, 08:38 AM   #3603
gijoe64's Avatar
Yes it will fit all TC chassis used for USVTA.
Raymon Robinson
ARC, LRP Go Blue!!
Old 01-30-2013, 08:47 AM   #3604
What is the F&R width ??
Old 01-30-2013, 08:55 AM   #3605
IndyHobbies.com's Avatar
Beauty! Will the body be sold seperately and in clear, or just it just come in RTR in charcoal?
Even if it doesn't get USVTA approval, or approval takes a while, it would still be a great one to own for shelf/display time.
So, its 190mm?
How about the mirrors...are they flexible material, or something that should be removed before racing?
Follow up: I see a seperate body. Cool:
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-gal_07.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-gal_01.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-gal_09.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-gal_06.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-gal_05.jpg
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 01-30-2013, 09:12 AM   #3606
SS LS1's Avatar
Trader Rating: 23 (100%+)
Very well done video! Thanks for posting the link. Watch the other video with the 5th gen ZL1 body, the'69 RS body makes an appearance in it.
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 01-30-2013, 09:55 AM   #3607
gijoe64's Avatar
This body is 190mm, the reason for this is the scale apperance we wanted.
We will have clear bodies for sale when the car is released.
Raymon Robinson
ARC, LRP Go Blue!!
Old 01-30-2013, 09:58 AM   #3608
gijoe64's Avatar
So, its 190mm?
The mirrors are flexible and you can leave them on for racing.
Raymon Robinson
ARC, LRP Go Blue!!
Old 01-30-2013, 10:11 AM   #3609
Even if it doesn't get USVTA approval, or approval takes a while...
Dont think a 190mm body will fit a USVTA legal chassis, the rear width of my TC4 is way more then 190mm
2013 SNOWBIRDS Pics & Videos
Old 01-30-2013, 11:16 AM   #3610
True...you might wind up with that Mickey Thompson drag racer look. You'd have to enlarge the wheel wells for that I guess.
USVTA #144
Old 01-30-2013, 02:20 PM   #3611
BIG JIM WOODMAN's Avatar
Trader Rating: 70 (100%+)
I just can't get passed the two part body and the giant bolts holding it together....
Love the basic body.
Hi, my name is Jim and I am an RC addict!
Old Guys Rule!
Bumper tag anyone?
BIG JIM WOODMAN is offline   Reply With Quote
Old 01-30-2013, 02:29 PM   #3612
Default VTA bodies
Originally Posted by IndyRC_Racer View Post
Pretty much every available VTA body has made the podium at big VTA races. There is no reason to avoid a heavy body (either from thicker lexan or heavier paint job). You may need to adjust roll centers or lower the body on the body posts, but that doesn't mean you can't win with a heavy body.
I have personally done well at a few big VTA races running a very heavy 'Cuda on a TC4 weighing in over 1600 grams. There is no ideal VTA body or VTA body to avoid. Just pick the body you like, put a decent paint job on it and have fun.
Well said Indy! It's all about the build, the paint, the driving skills and having a good time! At the speeds they run, weight is among the smaller issues. I know it's all relative but make it look COOL!
Old Guys Rule!
Bumper tag anyone?
Old 01-30-2013, 09:59 PM   #3613
IndyRC_Racer's Avatar
There is a reason none of the current HPI "VTA" bodies are 190mm - the HPI Vintage wheels have offset designed into them (Front have 3mm offset/rear have 6mm offset).
If you take an average TC running in VTA and measure the distance from the outside of the front left wheel to the front right wheel you should get a distance around 196mm. The rear should be a little over 200mm. This is the reason why HPI sells some of the RTR kits that have "VTA" bodies with 26mm wheels on the rear. Basically it is to keep rear tires from rubbing the body. For example with the 200mm wide HPI '65/'66 Mustang, you will get a bit of tire rub in the rear with the 31mm Vintage tires.
There is nothing to prevent any company from making their own plastic wheels that HPI Vintage tires will glue onto. Unfortunately if the wheels have less than 3mm offset, you could run into issues with the "VTA" tires rubbing on suspension parts like camber links or lower shock mounts.
It probably isn't a coincidence that the photos of the '69 body above are using low profile tires with probably zero offset front wheels and possibly 3mm offset rear wheels. Even then, there looks to be very little clearance between the body and the wheel. Not really ideal for racing conditions.
It may be possible to use thinner wheel hexes and get "VTA" tires to work with a 190mm body, but like I mentioned before it might interfere with suspension parts. Also, some Tamiya cars have a narrower track (less than 190mm), so it might be easier to get a 190mm body to work with that type of chassis.
Until someone purchases a body and tries it on their VTA car, we may never know how well it will work for VTA racing. I'm sure there is a market for these 190mm bodies, but I'll take a 200mm 'less than perfect race body' over a 190mm "scale appearance body" for my VTA chassis.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 02-07-2013, 09:02 AM   #3614
Tommy R's Avatar
Trader Rating: 19 (100%+)
Hey y'all,
I'm in the process of putting together a VTA car. I've been searching through the 240+ pages in this thread, but haven't seen much on how everyone is mounting their drivers. I'm interested in a realistic, scale looking driver and would appreciate it if some of you could share info/pics on how you mounted your driver. And if you don't mind, please tell us what kind of driver you're using.
Thanks in advance!
Tommy
Tommy R is offline   Reply With Quote
Old 02-07-2013, 01:30 PM   #3615
Meradin's Avatar
Tommy, I will post a pic in the other VTA thread as this is more for a show us your paint thread I think and less of the technical side. Go over to this thread for a picture...
U.S. Vintage Trans-Am Racing Part 2
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Vintage R/C Discussion/Pics/Selling/Wanted rcaddict Singapore R/C Racers 7291 01-09-2017 10:36 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Pics of Tony Neisinger's vintage RC12L paint jobs drbelleville Painting, Designs, Graphics and Photography 8 07-12-2008 04:09 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
