Old 07-24-2008, 12:18 PM   #16
IndyRC_Racer's Avatar
Here are the HPI '70 'Cuda bodies that I've painted so far using rattle cans.
Pink/Black: Testors Model Master Panther Pink (Dodge) '70/'71 28124 and Testors Model Master Flat Black 28134 (painted on inside)
Green Black: Testors Model Master Sublime Green (Dodge) '70/'71 28117 and Testors Model Master Flat Black 28134 (painted on inside)
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-hpi-70-cuda-panther-pink-lf.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-hpi-vintage-trans-am-bodies.jpg
IndyRC_Racer is offline   Reply With Quote
Old 07-24-2008, 12:18 PM   #17
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
Originally Posted by toycardriver View Post
I think he told me it was a Pegasus. He said it was rare so i was extremely careful when I painted it.
yes thats the company.
Pegasus Hobbies part numbers:
PGH4001 - 1970 Camaro SS
Id love to find more. I was lucky enough to find this 1 from a member here that was still new in package.
MONKEY BUSINESS RACING
Flinging poo at a track near you! Winning hearts and minds everywhere!
www.graphicmonkeydesigns.com
Brooksphotodesign.net
Flying Monkey is offline   Reply With Quote
Old 07-24-2008, 12:20 PM   #18
Okay, last one for today. A-main line up at Indy Slots (Indianapolis/Beech Grove) from 7/18/2008
Old 07-24-2008, 12:37 PM   #19
Here is a link for the Model Master's lacquer 3oz paint/rattle cans - http://www.testors.com/catalog_browse.asp?ictNbr=95
I have had no problems with this paint coming off in a crash. I am always careful when I spray using rattle cans to spray in multiple light coats and give each coat a chance to dry. I usually speed up this process with a regular hair dryer on high heat. I try to let the paint cure for at least 12-24 hours before I bash...er...race a body.
I should post a pic of my pink 'Cuda body because I've pretty much bashed the front end in. I've also broken the upper left corner of the body. Even with beating the heck out of it, the paint isn't chipping. I've been very pleased with the paints so far. It has opened up some more color options for me since I don't have the patience to maintain/clean a airbrush.
From what I understand, Testors let HPI use some of this paint so HPI could paint some of the bodies on their website. In fact the HPI '70 'Cuda body's instructions tell you which model masters paint they used to paint their pink car.
One last tip for the other rattle can painters out there - a warm can paints better than a cold can. I usually put a few cups of water in a small microwavable container and only heat the water in a microwave for about 2-3 minutes. I remove the water from the microwave and place the can of paint into the water. I let the can sit in the water until the can starts to get warm and immediately remove the can from the water. This gives the can a bit more pressure and makes painting a bit easier.
I should warn everyone that spray cans are under pressure. Use the above tip at your own risk. Should the spray can become too hot the pressure could rupture the can and could cause injuries. Do not place a spray can directly in/over an open flame or heating element. Do not attempt to heat a spray can in a microwave as this could be extremely dangerous.
Old 07-24-2008, 01:00 PM   #20
BobbyS's Avatar
Warming the can also makes too fine a mist if it's too hot and can waste paint. Frequently removing the can from the water is a good idea, and stop heating when you shake the can and the bearing is moving around freely inside. It doesn't take very long at all for the can to pressurize. Best bet is to keep the can inside for an hour or so before using it to let it get to room temp, then shake vigorously before spraying.
"After the third flip, I lost control............"
BobbyS is offline   Reply With Quote
Old 07-24-2008, 01:08 PM   #21
dodgeboy's Avatar
Send a message via AIM to dodgeboy Send a message via Yahoo to dodgeboy
here are some that I have paint for fellow racers
this one won concourse at The HPI challenge in NJ
and this is mine
dodgeboy is offline   Reply With Quote
Old 07-24-2008, 01:17 PM   #22
BobbyS's Avatar
The 42 is my fav! Is that paint or decal for the bumpers, they look super clean!
Old 07-24-2008, 01:24 PM   #23
TwoTone's Avatar
Originally Posted by SWTour View Post
Does the Model Master Paint seem to stick ok with crashing? I haven't tried it, but have wanted to.
Not at all, first hit and a ton of it flaked off my body. I won't use it again
TwoTone is offline   Reply With Quote
Old 07-24-2008, 01:25 PM   #24
speedsterblade's Avatar
dodge, It should be 'Clean Bodies by Bean'. Nice!
on the cans... I simply turn on the hot water and let the cans take a soak in the hot tub til the can is warm, not the entire can! bout half. Also always do a test spray before you think about pointing it to the lexan. you can have a bad can and ruin a good body. I also after shooting w/ each can, turn it upside down & spray until only air is coming out...then wipe off any paint left on the nozzle w/ a paper towel...they'll be good to go for the next coat or body. I use a big cardboard box as a paint booth to help keep over spray down.
speedsterblade is offline   Reply With Quote
Old 07-24-2008, 01:48 PM   #25
BobbyS's Avatar
Hate to be an old maid about this, but for the sake of the kids -- heating the can even with water from the tap can cause the gas in the can to boil after only a minute or less, even if you only warm half the can. Please don't try this at home without adult supervision!
Old 07-24-2008, 02:20 PM   #26
I see your point and someone could get really hurt and we can't be having that. Paint safely! I have noticed when left in hot water and it don't take long...the bottom of the can pushed out some...indicating pressure build up. nothing went boom so I kept doing it just used cooler water.
Don't breath the fumes either!
Old 07-24-2008, 02:22 PM   #27
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by IndyRC_Racer View Post
-Blue/White: Blue? and Pactra Sprint White RC251
oooooo I like the Blue/White one
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 07-24-2008, 02:32 PM   #28
k_bojar's Avatar
Everything on that body is ALL PAINT - except the BodiesByBean License plate
Old 07-24-2008, 02:50 PM   #29
Thanks for posting front/rear photos for the #42 Cuda. I'm not sure if I've ever seen a good photo of the rear bumper.
Sorry for opening a "can" of worms with warming a spray paint can.
I should also add that I finally learned my leason when painting and bought a decent paint mask. I try to paint outside (weather permitting in Indiana), and wear a mask to prevent breathing in the fine paint mist. Can't imagine the gunk that I put in my system from not wearing a mask.
As far as the Testors Model Masters spray paint, make sure that you use the lacquer based paint. If you use the Model Masters acrylic paint on an r/c body it will most likely fall off after impact. I will post a close-up of a body that has seen some abuse to show the results that I've had so far.
Old 07-24-2008, 03:21 PM   #30
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Ok, some of the few I ran last winter...
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Vintage R/C Discussion/Pics/Selling/Wanted rcaddict Singapore R/C Racers 7291 01-09-2017 10:36 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Pics of Tony Neisinger's vintage RC12L paint jobs drbelleville Painting, Designs, Graphics and Photography 8 07-12-2008 04:09 AM
SEO by vBSEO 3.5.0
