Like Tree7Likes
Old 02-09-2014, 08:31 PM   #4591
Default Help
I painted my first body using liquid mask and had a problem. I had two areas close together that I trimmed so they could be painted (the headlights an radiator on the front of my Audi R8). When I peeled off the masking, the masking in between to two areas lifted up too so the orange between the two (see picture) was supposed to be white. What did I do wrong and what can I do better next time?
John Wallace2 is offline   Reply With Quote
Old 02-09-2014, 08:37 PM   #4592
alloyslash's Avatar
Trader Rating: 19 (100%+)
I use 3 thick coats of mask and a new blade every time. How many coats did you use? Seems to me the thicker the mask is, the thinner the areas that can be cut are.
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 02-10-2014, 06:31 PM   #4593
DARKSIDE's Avatar
Some cars at Thunder RC
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-img_0795.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-img_0812.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-20140209_114122.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-20140209_114113.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-hallmustang.jpeg
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Scale Nationals
Windy City RC in Arlington Heights IL
April 8-9
DARKSIDE is offline   Reply With Quote
Old 02-11-2014, 04:31 AM   #4594
3 thick coats. I was actally thinking it was too thick. But then I did use the blade for some other things so it may not have been as sharp as new.
Old 02-11-2014, 07:04 AM   #4595
alloyslash's Avatar
I have always brushed on 3 coats of LFM, each in a different direction to get maximum coverage with no thin spots (hopefully). I use the #11 Xacto blades with the gold tint on the cutting surface as they seem to last the longest. I always use a fresh blade when starting a new body and have always had good luck, but thats just what has worked for me. I also try to lay the blade down at the most angle possible instead of straight up n down which helps with the cutting and also with maintaining a straight line, again its what works for me.
Hopefully others with more experience will chime in also
Old 02-12-2014, 09:11 AM   #4596
DARKSIDE's Avatar
http://www.historictransam.com/Cars.html
April 8-9
Old 02-12-2014, 09:15 AM   #4597
NutDriver's Avatar
Trader Rating: 14 (100%+)
CougarDartFalcon, CougarDartFalcon, CougarDartFalcon.............If I keep chanting it, maybe someone will make them.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 02-12-2014, 02:33 PM   #4598
snoopyrc's Avatar
I have been told by a good source that the Cougar is difficult to get to look right on TC dimensions. That would explain why there isn't one yet.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 02-12-2014, 02:57 PM   #4599
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
That would be one narrow track, long wheelbase car.
John Higgins
liljohn1064 is offline   Reply With Quote
Old 02-12-2014, 03:24 PM   #4600
Tommy R's Avatar
Wasn't the wheelbase only a few inches longer than the Mustang? Seems to be that would be easy to work around....might even give it better proportions.
Tommy R is offline   Reply With Quote
Old 02-12-2014, 05:03 PM   #4601
snoopyrc's Avatar
I don't make body molds so I can't say what is particularly difficult about it, but I don't think the with and length are the issue. Those dimensions are similar to the Mustang. Maybe it's the shape of the grill. Maybe it's the change in width, with the rear being 10mm wider than the front. I'm not sure, but I hear that out of the remaining VTA shells that have not been created, the Cougar is the more challenging. I do not know what feature is particularly difficult to model.
I look at the features on shells and it's interesting how different the quality is between brands. I think maybe Pegasus is the worst. The 70 SS is too wide. The side skirts hang to low. I don't know what they were trying to accomplish with the grill, and it webs really bad at the front corners. I see all of it's faults, but at the same time I can't carve out a mold, or if I did it would probably make the Pegasus look like a Tamiya shell.
Old 02-12-2014, 05:21 PM   #4602
Tommy R's Avatar
Ah, I hear ya.... Personally, the Cougar would likely be my last preference. It's just too close to the Mustang yet we've got so many other cool cars that could be manufactured that would be truly unique!
Old 02-12-2014, 06:19 PM   #4603
snoopyrc's Avatar
I would like to see them all made. I wonder about the ones with noses so short that you can't fit the TC bumper under there, or tail ends that are so long that you end up with all that lexan unsupported. In the end its about licensing and the trouble to make the mold.
Old 02-12-2014, 07:26 PM   #4604
SWTour's Avatar
If I'm not mistaken the wheel base of a Cougar vs a Mustang (in the VTA year range) was 3 inches different (108 vs 111) so in "our" terms, we're only talking .36 inches and most of the time we aren't "THAT" scale anyway.
I was working on some cougar decals a while back - hoping I could fit them on SOMETHING - sadly all I was able to save was a .jpg file - my vector got lost in a computer crash.
I've sent 2-3 variations of a early 70's style camaro decal to the vinyl printer - hopefully I can MAKE this thing fit on the McAllister IROC Camaro - even if it's not perfect -
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 02-12-2014, 07:33 PM   #4605
NutDriver's Avatar
The very Camaro-esque (69?) Firebird seems like it would be an easier project than most. A seperate nose, a la Protoform, and a set of taillight decals, a la SW Tour, seem like they would do the trick. Like Snoopyrc said, I can't make a mold (either) and my efforts would make the Pegasus look like a Tamiya.
USVTA member #111
Vintage R/C Discussion/Pics/Selling/Wanted rcaddict Singapore R/C Racers 7291 01-09-2017 10:36 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Pics of Tony Neisinger's vintage RC12L paint jobs drbelleville Painting, Designs, Graphics and Photography 8 07-12-2008 04:09 AM
