Batteries
Old 08-25-2003, 12:11 AM
  #16
Matt04's Avatar
do the 3000 and the 3300 have more punch than 2400
And which would you be better off getting 3000 or 3300 because dont 3300 need special care, and is that the same as 3000 or can u give them a bit of a bash around and there still good?
thanks Matt
Matt04 is offline
Old 08-25-2003, 12:17 AM
  #17
The newer 3300's can be abused more and still have good numbers.
Smartazz07 is offline
Old 08-25-2003, 08:39 AM
  #18
Joel Lagace's Avatar
Dont shop from towers. Go to your LHS or direct to the matcher. Towers is overpriced on most things.
My LHS always has high numbered SMC cells in stock the other LHS has high end POLEPOSITION CELLS.
Best advise is get a nihm charger and buy cheaper stronger higher voltage cells from GP. 3300s
Joel Lagace is offline
Old 08-25-2003, 08:57 AM
  #19
ajg
Registered User
ajg's Avatar
So would these ones from smc be good
http://www2.towerhobbies.com/cgi-bin...?&I=LXDPD2&P=7
ajg is offline
Old 08-25-2003, 09:07 AM
  #20
ajg
Registered User
ajg's Avatar
or would one of these be better http://www2.towerhobbies.com/cgi-bin...?&I=LXCZW0&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXCZV9&P=7
ajg is offline
Old 08-25-2003, 09:14 AM
  #21
CRASH's Avatar
Trader Rating: 26 (100%+)
Check out this site:
http://www.kinetixrc.com/
Later,
CRASH is offline
Old 08-25-2003, 02:56 PM
  #22
fatdoggy's Avatar
ajg - If your really not interested in soldering, then the batt's in the last two links you posted should keep you doing ok at a club level. They probabely won't be as good (less punch) as matched packs from matchers but for convenience(if you still run tamiya connectors) then they should be ok.
fatdoggy is offline
Old 08-25-2003, 03:50 PM
  #23
ajg
Registered User
ajg's Avatar
thanks fatdoggy!
ajg is offline
