Old 07-12-2008, 01:51 AM   #16
tc3team's Avatar
Originally Posted by CREWMAN View Post
what can i do to stop spinning out in the turns. Most of the time it is from the center to he exit of the corner. the back end of the car loose traction and spins around. Now i understand that this is commomn when you are going to fast but somtimes i am going pretty slow and it still comes around on me.
Also make sure your droop settings are equal and you have no chassis tweak. A bad choice of droop setting can make the back end unstable, if you are running a roll/sway bar on the back take it off.
Also try adjusting the rear suspension settings to get the car to grip that end.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Asphalt Touring Car Racing with Foam Tires: Set-up tips and Info yyhayyim Electric On-Road 5 04-14-2013 02:18 AM
Asphalt Gearing (Touring Car and 10th Pancar) rinkrat99 Electric On-Road 1 05-29-2007 09:57 AM
Asphalt Touring Tires for Sale!! CHEAP!!! FreqETag R/C Items: For Sale/Trade 4 07-25-2005 09:21 PM
Asphalt Touring Car Racing in Rockford, IL (Nitro and Electric) TheBarber Track Locator Forum 5 07-03-2003 08:29 PM
SEO by vBSEO 3.5.0
