Old 07-07-2008, 07:51 AM   #1
Trader Rating: 42 (100%+)
Default motor coolers and brushless motors
does anyone to this to their brushless motors? or should a fan just be on the motor ?
josh short is offline   Reply With Quote
Old 07-07-2008, 08:08 AM   #2
Bigshades's Avatar
Trader Rating: 22 (96%+)
I know that chilling a Brushed motor will help it a little, because when the magnets get hot, they lose a little strength.
Possibly you could assume the same for a BL motor. If you keep its rotor cool, it wont lose magnetism.
I havent tried it, but it might help a little if you've got a larger pinion than a spur!
Bigshades is offline   Reply With Quote
Old 07-07-2008, 08:48 AM   #3
I played a little with a motor cooler in 12th. It seems to help a little up front but the motor still reaches the same temp by the end of the run.
I had better luck with a clamp-on heatsink and a fan because it actually reduces the motor temp for the entire run.
With a bit of dremel work you can rout the novak heatsink around the axle of a 12th car and put a fan on it. Makes a big difference in 17.5.
Fred_B is offline   Reply With Quote
Old 07-07-2008, 11:38 AM   #4
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
I have to agree with the use of a motor cooler being only good for the initial part of your race as my experience also showed that the motor still hit the same temps at the end of the run.
More recently I have ditched the motor cooler and fans on the motor and am finding performance no different. I think its best to understand the temps of your motor (brushed or brushless) and how gearing affects this.
Coolers and fans could skew these results and could possibly lead to a situation where your fan dies mid-run and all of a sudden your motor hits its threshold temp and burns out
Fans also add weight to your car
mok is offline   Reply With Quote
Brushless Motor Failures and Motor Coolers or8ital Electric On-Road 54 10-03-2008 12:11 PM
Motor Coolers? aus jd 2703 Australian Racing 9 07-19-2006 12:21 AM
** Motor Coolers ** nordheim R/C Items: For Sale/Trade 26 07-02-2006 09:18 AM
Motor Coolers micros_rock R/C Items: For Sale/Trade 26 06-23-2005 12:29 AM
motor can coolers SRW141 Electric On-Road 12 01-24-2004 03:38 PM
SEO by vBSEO 3.5.0
