Spy Shot: New Brush to Brushless Motor dyno Converter Module
Here you go guys a innovative item I saw at a TCS event in Vancouver. On the pit bench Keith Yu was checking a Brushless motor with a regular brushed motor checker. But in between the motor and the outputs is a converter module. Here are some pics:
Alfred
Alfred
With out sensor?
Just because i don't have SP esc then don't need it's ESC tuner function, just need a simple BL module converter to put working with my MM motor tester.
from what I saw you do not need a sensor cable so it should be able to do sensored or sensor less motors. Also you do not need a speed control just your motor checker you used for brushed motors
Guys, its just a speed controller. Its fixed at full throttle. All the controller does is convert the DC to the proper AC current a BL motor needs.
When the dyno increases or decreases the voltage, it directly changes the input to the "controller", which effects the motor. Its very simple, and i think its a great idea.
You could make this with any brushless speed controller, you would just have to have it at full throttle. You could easily do this with a Nitro's fail safe, instead of using your radio.
Cheers!
Cheers!
Why wouldn't you use use Novak's Sentry with the brushless harness? It calculates RPM from the Hall sensors.
http://www.shopatron.com/product/part_number=5365/135.0
I hope thats a good hall sensor for $15. My robotics team at my high school was using $50 ones to help us calculate distance in autonomous mode and they are by far the most bitchy things ever to set up. On top of it we were using gears twice the size spinning at 10,000 RPM. And we tested 4 of them we had and they all were missing teeth. I highly doubt the hall sensor on that Novak will be accurate... It might be close but I bet it will miss a few teeth... so a converter would be the best bet IMO.
The hall sensors are already in the motor. $15 is expensive for a hall sensor, $50 is - . All sensored brushless motors have 3 hall sensors and they work over 50000 rpm fine and I bet they cost less than $1 each in small quantities.
Imho these devices are a waste of money. A brushless motor is only worth testing when used in conjunction with the esc. That device will not know how your esc drives different types of motors so it's info is not that usefull. I took the time to post my experience with dyno testing brushless here - http://www.rctech.net/forum/showthre...39#post4291139
I was hoping other people would take part in this but I guess I was being optimistic . I gave my old laptop to my sister so have not had much chance to do more testing but I'm looking at getting a new laptop anyday so will be back testing soon .
I am assuming this is only for Speed Passion motors ESC's but it looks nice...
I like seeing more tuning tools for brushless coming out....
http://rctouring.eu/images/328_BA_small1.jpg
We are proud to release the first brushless system analysis tools:
Brushless Analysis for brushless ESC and Motor:
This is a first brushless Analysis tools for R/C Car, R/C boat, R/C airplane
and R/C Helicopter
Feature:
Digital Brushless motor checker function
Brushless Analysis for ESC and Motor "Suitable for Speed Passion ESC, LRP,
Novak, GM, ESC"
Brushless ESC - updates function for Speed Passion GT ESC series
Build in USB update able feature for Brushless Analysis
and R/C Helicopter
Feature:
Novak, GM, ESC"
Greetings Victor
It's not a sensor it's just a Y harness
