Lipo Sack Under $10
Lipo Sack Under $10
We have all seen the Lipo Sack selling at the LHS and online for $30+. Now I am all for supporting the LHS and some online places, but when you can get the same thing for under $10, I figured I would share the info w/ other racers.
We have all seen the Lipo Sack offered at the LHS and online:
After doing some quick searching, I found this fire resistant document bag:
Sure looks a lot like the Lipo Sack to me.
The document bag that I found sells for anywhere from $9.95 to $13, depending on the vendor. The cheapest place I have found it was here - http://www.colonialmedical.com/produ...roductid=20501.
With the rising price of gas, every little bit helps.
Never seen one of those things being use yet ....
Some guys at my local track use the Lipo sack. Thanks for posting that link.
It looks like someone (ROAR?, race organizers?) is going to have to figure out what is considered fire resistant enough to be called a LiPo sack.
Good catch Rick, just because it says fire resistant does not mean its fire proof. I would not want ROAR to have an approved LIPO sack list but I would think track operators might want to know what's needed....
Hope the wife will like it too.....
8.3.1.6.3 - All Lithium Polymer packs used for motor power must be charged inside a “Lipo Sack” or similar fire mitigation device proven to withstand a minimum of an 8.4v 5000mah Lithium Polymer pack failing destructively without showing external flame.
Now I highly doubt the people that make the document pouch detonated a lipo inside, but at the same time, are any of these types of bags tested from the inside? One would assume all types of fire resistant / proof bags are tested from the outside. These are designed to protect the contents on the inside from flames, not the other way around.
Can't find it right now, but didn't Dawn of ROAR actually post a link to those exact bags as an alternative to the "Lipo Sack"? I believe it was in the thread that was announcing ROAR's approval of Lipos.
additional info
Fire Resistant Document Bag
Features:
Withstands Up To 1000 F
Holds Legal Size Documents
Protects Valuable Documents from Fire
Protect Your Property Deeds, Passports, Birth Certificates, Cash, Photos & More
It's like a fire safe for your important documents that you can't afford to lose. Fire Resistant Document Bag protects your valuable papers inside. Holds up to legal size documents like deeds, passports, birth certificates, cash and more. Fiber glass construction. 9" x 14 1/2"
Warning: Do not wash or immerse bag in liquid. The bag is made of fiber glass and may occasionally shed fibers during use. Make sure to wash hands after each use. This bag is not a substitute for a safe deposit box.
http://www.asseenontvguys.com/index....ROD&ProdID=317
A normal house fire is around 1000 to 1500 degrees. Being stored in something would give this bag a good fighting chance to survive a house fire.
Worth it? I think it would be.
Well the big brown truck came today w/ the fire resistant bag from the medical supply link I posted.
It is not an exact copy of the Lipo Sack, but it is very close. It is made out of a different type of material, more flexible and softer than the Lipo Sack.
The other difference is the top of the bag does not open and close like the Lipo Sack. The top is sealed on both sides, with a slot to insert items into the bag.
