hot bodies cyclone HELP please !!!!!!!! >
Old 07-02-2008, 07:36 AM
cyclone speed's Avatar
Exclamation hot bodies cyclone HELP please !!!!!!!!
hi i have a hot bodies cyclone moor speed and every time i de tweak the car and i use the same setup as the other guys uses at my local track every time i break on corner entry and i turn , my rear end slips does a 180 and the time i settle up again i have lost 5 sec .it happens nealy every time i corner thanks if you could help me it will be very usefull thanks
cyclone speed is offline
Old 07-02-2008, 09:21 AM
Trader Rating: 23 (100%+)
have you tried to set up correct camber angles? that can help a lot.
not home is offline
Old 07-02-2008, 09:37 AM
TheCoolCanFanMan's Avatar
Check your rear diff, and make sure the thrust race is not binding up. Check your droop from when the car sits on your setup board, lift the rear of the car using a driver in the middle of the base of the chassis, and make sure both wheels come of the deck at the same time, check front and rear for this, check the shocks are not collapsing when entering a corner. hope this helps
Malc
TheCoolCanFanMan is offline
Old 07-02-2008, 09:52 AM
sounds like you have a one way installed instead of a spool or diff.
bionictony is offline
Old 07-02-2008, 11:45 AM
do you have a setup cheat of your setup?
it can be a lot of things.
like the motor brkes to hard.
your steering settings on your transmitter.
your tires
the diff
your drifing style.
As the other HB drivers can drive your car, than you must change your setup or your driving style.
mikky32 is offline
Old 07-02-2008, 04:21 PM
I have had the same problem. I did not realize it but I had the steering endpoints too high and the tires would turn and the CVDs would bind and slow the front tires down enough to spin the car.
Corinator
Corinator is offline
Old 07-02-2008, 10:33 PM
When you say de tweaking, are you just loosening and tightening the screws back up and throwing it on the track .....or are you doing that, throw it on a tweak station to get the shocks right, then adjusting ride height, droop and everything from there ?
What you are describing sounds to me like you need to put your car on a tweak station. Mine used to do the same exact thing, i didnt know what it was til someone put it on a tweak station.
Car could be out of balance
Bearing could be bad - change or clean your bearings
Diff might need to be rebuilt
wcalaker is offline
Old 07-02-2008, 11:23 PM
mine i did put it on the tweak station adjusted everything and ride height ........
but i tought of one probleme that it might be maybe im wrong
i tought of that : i am using a diff at the rear and one way pulley front and instead of using a fixed center pulley (normally not used with one way diff) i am using center one way so it means that every time i brake the car brakes with only 2 wheels (the rear wheels) and maybe my diff is not very well adjusted and i dont know how if i know if its well adjusted if anywone could tell me how it will be great full
i thought of putting a fixed center pulley on a one way like this the car would break with 4 wheel drive
and i forgot to mensione that the car , when i break instead of going on the side where there is more weight , (the left of the car where ther is the motor , ESC servo and receiver) if goes to the right where there is only 5 cell the less weight
THANKS
Old 07-02-2008, 11:35 PM
Trader Rating: 38 (100%+)
or8ital is offline
Old 07-03-2008, 12:24 AM
^^ that picture sums up all that I have been thinking reading his posts.
LOLOLOLOLOLOLOLOL n00b,
Corinator
Old 07-03-2008, 05:38 AM
mangoman's Avatar
If you have a one-way in the car it will always spin out under braking. You will have to learn to drive without brakes or take out the one-ways.
This is the same for any car.....
mangoman is offline
Old 07-03-2008, 07:11 AM
thekthai's Avatar
Default hi regard hb cyclone
NOW get this setting,,,,
From surikarn setting,,,,
sus blog spacer 1.5 all around
3hole piston 60oil Front 55Oil Rear
-2 camber F-R
+1 toe out Front
3 rear toe in
LRP and Nosram ISTC
4.5 BL 6 cell ratio8.0
5 cell use 3.5T ratio 8.9
thekthai is offline
Old 07-03-2008, 09:30 AM
recklessryan's Avatar
Smile middle plate
the heatsink mid-plate that the moore speed comes with is very stiff. if your problem is very minimal you can try removing the two back 2mm screws and leaving them off, or the two front 1.5mm screws is a more minor change. for a worse spin out, try the carbon fiber plate from the other cyclones, or the fiberglass one from the new "cyclone tc", which gives you even more flex(x-rays have been designed for a much wider range of this adjustment). Although basic setup and maintenance can also be the problem, so try that before buying new parts. the other posters talk about changing to spools from one ways and checking droop especially, since that is the classic setup area for your problem. your pro4 book might say right in there that droop is the problem. personally i have the carbon fiber plate, and it is till not enough because i have to set my droop to maximum down travel(about 2.75 with my shock/spring setup), so im buying the fiberglass part. good luck
recklessryan is offline
Old 07-03-2008, 12:07 PM
Yes but normally when you put the one-way it acts like a diff (each wheels will spins at different speed when you corner).
But will the spool help in this probleme , because normally the spool is a locked diff so it souldn't help maybe im wrong , and could someone tell me when is the spool needed or the one-way .
Old 07-03-2008, 12:11 PM
RC MARKET's Avatar
Good tips !!
RC MARKET is offline
