Old 07-03-2008, 01:46 PM   #16
I love running a spool in my cyclone. With my 2.5turn brushless its pretty much a necessity to run it. I also like the handling. It does seem to push when going into a turn but the locked diff just claws out of the turns. I vastly prefer it over the front one way even when I'm running a stock motor. I don't race on carpet so I don't like the one way.
Just Run the Spool You Will Be Happy,
Corinator is offline   Reply With Quote
Old 07-03-2008, 02:00 PM   #17
mangoman's Avatar
Originally Posted by cyclone speed View Post
Yes but normally when you put the one-way it acts like a diff (each wheels will spins at different speed when you corner).
But will the spool help in this probleme , because normally the spool is a locked diff so it souldn't help maybe im wrong , and could someone tell me when is the spool needed or the one-way .
Im not sure what you are referring to here but if its in reply to my post. There is NO setup change that will allow you to use brakes with a one-way (either front, center or both), unless you are talking about light drag brakes on the speedie.
Using a spool or diff with a fixed center pulley will allow you to use brakes if required. Most cyclone drivers seem to prefer the spool on asphalt unless the track is really tight and twisty. The spool has less initial turn in however this also makes the car more stable to drive. The spool has the advantage of allowing you to get on the throttle more aggressively when coming out of a corner.
Hot Bodies Cyclone!!!
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 07-03-2008, 09:42 PM   #18
^^ what he said.
Old 07-03-2008, 09:51 PM   #19
Yeti35's Avatar
mine i did put it on the tweak station adjusted everything and ride height ........
but i tought of one probleme that it might be maybe im wrong
i tought of that : i am using a diff at the rear and one way pulley front and instead of using a fixed center pulley (normally not used with one way diff) i am using center one way so it means that every time i brake the car brakes with only 2 wheels (the rear wheels) and maybe my diff is not very well adjusted and i dont know how if i know if its well adjusted if anywone could tell me how it will be great full
i thought of putting a fixed center pulley on a one way like this the car would break with 4 wheel drive
and i forgot to mensione that the car , when i break instead of going on the side where there is more weight , (the left of the car where ther is the motor , ESC servo and receiver) if goes to the right where there is only 5 cell the less weight
You answered your own question. You are running a one way and it does not matter if it is center or front, you can't brake going into corners. You have to do it before the corner. There is no braking action from a one way period. All the braking comes from the rear. So yeah, you will spin out braking into a corner with a one way. Go to a spool or a diff up front if you want braking front and rear.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
SEO by vBSEO 3.5.0
