Old 06-30-2008, 06:38 AM   #1
cyclone speed's Avatar
Arrow hot bodies cyclone setup
hi i have a hot bodies cyclone moor speed WCE and i run at wlrc race track . I was wondering if anywone could help me out please .I would like to know you guys setup at wlrc for this car
This is my setup :
108 spur and 35 pinion
3mm spacer between the upper bulkhead and the inner pivot for front
and 2mm between upper bulkhead and inner pivot for rear
5mm front ride height
5.5mm rear ride height
5.5mm droop front
5mm droop rear
standart suspension 2 holes ,1mm each ,40w oil standart spring gold rear silver front
camber 1.5
castor 4
wheelbase is standart
and for the "dive" and"squat" is: 1.5mm under the suspensionpivot block rear
and 2mm front suspension pivot block and 1mm under rear front suspemsion pivot block dodge stratus bodyshelle
for the toe angl because i dont have the proper tools to mesaure it there is 25mm difference between each palstic thing that screw themselves to the turnbuckles
4mm ackermann
and i think thats it
for the elctronics:
lrp5.5turn gearing 7.5 (108 spur 35 pinion)with novak GTB 1st brushless profile with gemini 2 transmitter with micro 41 mhz receiver and T2M diamond digital servo (0.12 @ 60 , 13 kg torque) and finally i have 1 pack of orion SHO 4200 batteries , + 1 pack of demon ep 4200 + 2 pack of LRP hv2 vtec 4200 bigmama
and i forgot to say that i never run there when there are races i only go weekdays to practice myself
Thanks alot if you guys could help me out
cyclone speed is offline   Reply With Quote
Old 06-30-2008, 07:38 AM   #2
STLNLST's Avatar
Trader Rating: 17 (100%+)
there's a hotbodies thread on here already so if you copy and paste this on there I'm sure the help will come flowing.
STLNLST is offline   Reply With Quote
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
WTB: Cyclone One Way Setup vazzo Australia Wanted to Buy 1 07-15-2008 03:27 PM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
good asphalt setup for a hot bodies cyclone Rasmus TbEvo IV Electric On-Road 4 05-20-2006 11:18 PM
cyclone setup RKeasler Electric On-Road 1 08-22-2004 09:41 PM
SEO by vBSEO 3.5.0
