Old 06-29-2008, 06:48 AM   #1
crabboy's Avatar
Trader Rating: 57 (98%+)
Default Rotor sizes?!?!
Hi guys,
Have looked around for a while but can not find any info on this topic, I need to know what differnt dia. rotors do! I have 2 differnt sized rotors a 13mm and a 13.5mm and I need runtime from my car, which rotor would be best for this? What will each rotor do? Any help would be greatly appriciated!
Thanks guys,
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 06-29-2008, 02:17 PM   #2
Trader Rating: 16 (94%+)
A larger rotor increases torque, and reduce peak rpm's.
A smaller rotor decreases torque, but increases peak rpm's.
kn7671 is offline   Reply With Quote
Old 06-29-2008, 02:45 PM   #3
mainracer's Avatar
Send a message via AIM to mainracer
the 13.5 rotor will be more efficient. The 13 will feel smoother and will have more rpm.
Hope this help !
Keven Hebert
AE / Reedy / LRP
KOpropo / Much-More / Parma PSE / Protoform / APS ceramic Bearing / BawdyShop / Fastcats / Dekelz
mainracer is offline   Reply With Quote
Old 06-29-2008, 09:44 PM   #4
Going to a larger diameter gives you more bottom, but less mid and top
phumpy is offline   Reply With Quote
Old 06-30-2008, 12:46 AM   #5
razzor's Avatar
Different rotor diameters changes the feel and characteristics of the motor and while they will have some influence on runtime the biggest factor would what winding motor you are using and the gearing you run.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-30-2008, 03:18 AM   #6
Smaller rotor will improve runtime... But needs to be geared a little less too due to the reduced torque. More notable will be the increase in drivability.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
380, 540, 550, 720 motor sizes? haulin79 Electric Off-Road 16 05-07-2016 05:26 AM
Speedo sizes UltegraSTI Micro and Mini Scales 3 07-23-2008 07:39 PM
brushless: Rotor sizes~torque more$thanbrains Electric On-Road 6 02-02-2008 07:06 AM
Brushless Rotor Sizes Jake S Electric Off-Road 5 02-01-2008 12:42 AM
Novak 13mm rotor and regular 12.3 rotor wallstreet Electric On-Road 1 01-09-2008 11:55 AM
SEO by vBSEO 3.5.0
