Old 06-27-2008, 10:52 PM   #1
cyclone speed's Avatar
Unhappy brushless timing
hi i would like to know what effect will the timing be on a lrp vector 5.5 .
It has 0 ,2 ,4 ,6 ,8 as timing and i would like to know what it will do if i raise the timing (0, 2 ,4 ,6 ,8 ) or if i decrease it (8,6,4,2,0) will it have more torque more power more rpm ? i dont know my standart timing that came with the motor is 2
Thanks alot if you could help me out
cyclone speed is offline   Reply With Quote
Old 06-28-2008, 04:32 AM   #2
Trader Rating: 16 (94%+)
From my understanding, it mostly moves the powerband around, NOT increase or decrease power.
You are better off leaving the motor timing alone (stock setting), and changing the gearing slightly in your RC with Brushless motors.
kn7671 is offline   Reply With Quote
Old 06-28-2008, 04:36 AM   #3
Personaly I just wouldn't change it at all. The way it comes is the way lrp has set it so that it works best. I've heard some people changing the timing on the lrp's and they only advance it by no more than about 2mm. Unless you really know what you are doing its not a good idea. On other forums i've heard of people wrecking brand new motors by changing the timing on a brushless.
sean0 is offline   Reply With Quote
Advance Timing on Brushless motor? z28mccrory Rookie Zone 5 09-01-2010 08:45 AM
Novak GTB & 10.5 Brushless Timing Question mutley001 Electric On-Road 26 10-19-2009 09:31 PM
Brushless Motor Timing Adjustment gansei Electric On-Road 0 03-23-2008 09:43 AM
Timing vs. Power (Brushless) SWTour Electric On-Road 16 12-11-2007 04:22 AM
adjustable timing on nosram brushless redlinezak Electric On-Road 0 03-10-2006 08:19 AM
SEO by vBSEO 3.5.0
