Awesome 13.5!
Awesome 13.5!
Hey all. I got a quick question.... Which 13.5 brushless do you guys think is the best performer? I would like something with lots of torque and punch so that I can gear it up higher than usual... I was considering a Novak ss 13.5 but I would like to know what everyone else thinks. I will be running this motor with a speed passion GT. Thanks in advance for the input!
Michael
Michael
Well I can tell you from a quality and assembly standpoint, that the new LRP Vector X11 Stock Spec motors are the best 13.5 Brushless motors I've seen to date.
I recently disassembled and compared the following motors: (in order of my opinion of the quality of the motor)
Novak SS13.5 Pro
Speed Passion 13.5/27T
Losi Xcelorin 13.5
Hacker E40 17.5 (same motor as the Losi, wired instead of plug)
If in doubt, I don't think you can go wrong with the tried and true Novak SS motors.
Novak SS13.5 Pro
Losi Xcelorin 13.5
Novak SS13.5 Pro
Losi Xcelorin 13.5
Novak SS13.5 Pro
Losi Xcelorin 13.5
Does the LRP motor have a nickel plated rotor? From what I understand nickel plating the rotor gives you better operating temps and has more torque. (correct me if I'm wrong) How does the LRP compare as far as gearing compared to the novak?
I have run the following motors with Touring Car, Stock, Rubber on Asphalt.
Speedo's: Speedpassion GT LPF V1.1, LRP Sphere Comp TC, and Novak GTB.
Rating from me.
1. Speedpassion - reason I like this best is due to ease of adjustability.
2. LRP Sphere
3. Novak - reason I like this least is adjusting is complicated and I need instructions every time.
Motors:
Speedpassion 13.5 is fastest but not as tourquie
Novak 13.5 is very tourquie but not as fast
never tried LRP
just my 2 cents...
Rating from me.
2. LRP Sphere
Motors:
never tried LRP
just my 2 cents...
Thanks everyone for the input! It sounds to me like the Novak ss13.5 would suit me best, still interested in the LRP motor though... Does it have a nickel plated rotor? You'll know because it has what looks like a chrome finish. Anyone?
As for gearing, couldn't tell you, I just got my LRP motors. I think the gearing will be similar to Novak.
The new rotor is black, but with nickel plated sintered magnet, just like the Novak. The new LRP rotor has a large diameter bearing on both ends, Novak only on the pinion end.
How do you know if the motor is a new release? I bought a trinity duo about 2 months ago and they already have a new release according to the website... I don't want to buy a motor off the shelf of my local hobby shop only to get it home and discover that it's a old release. How do I know the difference between the old LRP motor and the new LRP motor???
As for how you know what motors are new and old, you have to research and pay attention to the boards and various websites. A good website that posts new info on products is www.redrc.net. In this case you can go straight to the manufacturers website and read about the motors.
http://www.teamassociated.com/lrp/motors_vector.htm
Is this the new DUO you were referring to? If so, that is a fine looking motor! That blows away that cookie cutter Feigao looking thing they were selling. I have to believe that Trinity is going to be on top of the brushless game before long, and maybe these new DUO's are the start of it? I know they're not happy being pretty much the standard in brushed and an afterthought in brushless.
Super Moderator
Really? Good for Feigao then. Looks like they're movin up in the world. That looks like the same can Speed Passion is using on their Comp 2.0 mod motors.
Mark
What is a good temp range to run the LRP at?
