Like Tree3Likes
Old 07-19-2017, 06:11 PM   #76
How did you get 6mm ride height ? I have a X-12 and would really like to do some outside running.
sgtlt is offline   Reply With Quote
Old 07-20-2017, 10:32 AM   #77
TJames987's Avatar
Trader Rating: 10 (92%+)
Default having a blast outdoor w 1/12
First of all I buy the Xceed tyres and do not true them at all and run them full size so it starts at 7-8mm ride ht. As the tyres wear down I remove the front bulkhead shims to raise the front and use the eccentric in the rear as needed to keep 5-6mm ride ht. Also noteworthy is that tyre-wear seems pretty minimal! I have the 2014 xray x12 for reference.
TJames987 is offline   Reply With Quote
Old 07-21-2017, 08:10 AM   #78
Airwave's Avatar
Same here... On asphalt you can run with more foam on your wheels than on carpet.
Airwave is offline   Reply With Quote
Old 07-21-2017, 05:00 PM   #79
We run Ulti tyres straight out of the packet. Our asphalt track is smooth so 4mm ride height works, but you should be able to get 6mm ride height before they wear too far.
Scott Tapsall
Queensland Radio Circuit Car Racing Association
Pine Rivers Model Powerboat Club
Scott_T is offline   Reply With Quote
1/12th scale on... Asphalt? Bigshades Electric On-Road 35 02-22-2015 03:48 AM
Best 12th Scale for Asphalt... RC12 Electric On-Road 18 04-15-2013 01:21 AM
What 1/12 scale foam compounds on asphalt DustinR Electric On-Road 7 04-17-2008 04:15 PM
What would be the best choice for asphalt 10th scale oval? Ginsu Oval, Larger Scales and More 3 02-16-2005 02:50 PM
Hot set-up for TC3 asphalt??? Dreamer Electric On-Road 2 05-10-2003 12:14 PM
