Old 05-21-2008, 09:54 PM   #1
Drift_Buggy's Avatar
Trader Rating: 20 (100%+)
Questions?? Gearing Tight?
Got a TC4 with a Peak 15T motor in it with a 24T pinion and standard 72t spur (think). It seems really stiff and hard to push while not running. Would this be from the diffs being to tight or pinion/spur to tight? Motor endbell gets hot really quick
Drift_Buggy is offline   Reply With Quote
Old 05-22-2008, 03:03 AM   #2
NOZ69's Avatar
Hey drift_buggy,
The TC4's will always seem tighter compared to a belt drive car, i'm guessing that the pinion might be too tight.
You should be able to rock the pinion slightly without moving the spur, try this on several different places as you might find a tight spot.
Another way to find the right mesh is to use a cigarete paper between the pinion and spur.
FT TC4, LRP TC Sphere, LRP X-11 13.5
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
NOZ69 is offline   Reply With Quote
Old 05-28-2008, 01:17 PM   #3
Have you changed out or done ne work to the differential or output drives?
pacteam07 is offline   Reply With Quote
Old 05-28-2008, 01:20 PM   #4
rjs_13203's Avatar
something tight in ur gear mesh or drivetrain.
rjs_13203 is offline   Reply With Quote
v-spec really tight ruggydriver Nitro Off-Road 3 07-28-2008 10:41 AM
Tight servo robotdoblador Radio and Electronics 6 02-08-2008 07:54 AM
To tight of a pinch? pinky2252s Nitro Off-Road 3 11-25-2007 02:15 PM
tight xxx-s Electric On-Road 6 12-27-2006 11:40 PM
Belt too tight? The Black Kat Electric On-Road 4 06-14-2004 07:41 AM
SEO by vBSEO 3.5.0
