Go one heavier front and side spring. I am running a wide front to use spec front tires. If you have corner exit problems try a thick dampener fluid. This seems backwards but I had good luck going stiffer on the single (RC18T rear) side shock that I use. Gear up to a 72/29 for a really long track in cool weather. Get a thunderpower battery if allowed. It has really good voltage.
Stranahan-RC.com Suspension kits, CRC Factory Parts/Tools (from chassis to Arms), Alloy Steel screws JohnStranahan@aol.com
TeamCRC.com Mikes-HobbyShop.com
Home of the 2010 200 mm Internal Combustion (IC) Sedan Worlds
http://2010ifmar200mmsedanworlds.com
We have started treating the track before club races. This has brought up the need for new setup items. I was running CRC WGT spec fronts for a little more grip previously. Now I was getting some mid corner spins with them. I took some suggestions from the thread to mute some steering and bring them back in. I widened the front. I also lengthened the car. As the car was very near my wide pan width in the front I put on a favorite front setup. Purple springs, 4 degrees caster, and I added 5 degree reactive caster blocks.
Reactive Caster Blocks
What a reactive caster block does is it removes a little caster as the car rolls. mid corner a 5 degree block removes about 1 degree caster. This softens the steering right where I had a couple of spins.
The new front worked well in practice. I will need some getting used to it as I can add more power in the corner and just after than before. The sweeper is not quite hooked up but race day track prep should cure that.
Note this car has the original suspension with the exception of Nerf wings and a single RC18T side shock with 40 weight oil now.
Had a little more test time on the offset rear pod. This tightned up the car a bit and seemed to add rear traction. Was able to run gray rears on carpet instead of white or pearl white. Car still had a slight push, should have gone even harder in the rear but ran out of testing time. Turned equal laps to the centered car with softer tires. So should be faster if I can get a setup that turns well.
so the pod did what I wanted, added LR weight in the 1 cell and tightned up the car a little. Now I need to work on a setup that takes advantage of this. Was able to go to the long LF arm along with the higher roll center blocks. this seemed to really help the front end work well. RF is no longer wearing a lot faster than the LF. Rear still needs to be freed up a little, but should be able to get there with springs/tires.
John Fisher
Team Epic
09 star 45 national champion
08 Julie Ayres winner
07 10R national champion
inevitably. I'll will need to ask a few questions first.
John
CRC Gen X 10 gt / 12r5 , / Xray 09 , xray t2r pro / Losi 10th slider and Losi Mini Late / Tekin RS PRO , RS / Specktrum Dx3r / Express Motorsports u been tagged / Finishline Product / Barney's Racing / Dirtburners thanks Bill
LAZER SPEEDWAY where all else IS just a parking lot / Woodville Mall Raceway
This is a dual A-arm front end, 3-link rear end, offset pod, 1/10 oval car.
Here is a list of nice features.
1. The 3-link offset pod had more forward and cornering traction which allows the use of harder rear tires. The car rolls more freely in 1-cell stock or super stock racing. The rear end has Hyperdrive offset pod right hand hub and 1/2 inch narrow left hand hub.
2. Adjustments available to the rear include:
wheel offset
rear steer in either direction
roll steer
roll stiffness by changing springs
left rear preload by adjusting the left rear spring collar down.
Antisquat
3. Center of gravity is lowered by use of two vertical shocks intead of 3 high horizontal shocks.
4. The dual A-arm front end has more precise and more abundant steering. You no longer guess to the mark ahead of time, you drive to the corner mark.
5. The front end has independent roll center and camber adjustment unlike our inverted strut suspensions. In other words you get the roll center you want regardless of the tire camber, a roll center adjustment actually does something when you change it.
6. The front end is fully dampened by coil over shocks.
7. The front end includes droop screws shown in photo two.
8. This setup came out with good ackerman (arms perpendicular) and 0 bumpsteer. Steering axles don't move with bump. Clearance from Servo Saver to suspension is satisfactory using the middle holes on a small servo saver.
9. The same drill template used for the Gen X 10 front end will work on the battle axe. Two additional holes must be drilled for the 3-link exactly .7 inches forward of the forwardmost side link holes. My side links are longer than the Calandra long side links.
This, in my belief, is the oval pan car of the future. This individual car is availble right now sans electronics. Send me an e-mail to JohnStranahan@aol.com. No it is not cheap, just the best.
