Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 08-17-2009, 08:35 AM   #1066
You can download a SolidWorks 2009 trial version for free. But I think it works just 90 days.
Der Dicke is offline   Reply With Quote
Old 08-17-2009, 09:12 AM   #1067
Originally Posted by V12 View Post
John
is there an easy to use, inexpensive CAD program what could be used for designing car parts.
I have some ideas on making some different parts for my cars but donīt want making them myself. Just designing and then giving the files to a machining shop.
Try Alibre. Nice program and the price is definately right. I have been using the trial version for 2 years to do mock up furniture designs. I believe they are now selling it for $99 if you want the full version. Worth looking into.
http://www.alibre.com/
Shawn.
Shawn68z is offline   Reply With Quote
Old 08-17-2009, 10:07 AM   #1068
Ditto on Alibre. I've designed several parts and sent the DXF to my brother who cuts them out with a CNC router.
There is a minor learning curve but just follow the tutorials and you'll figure it out.
Brevard Electric Auto Racers- Palm Bay, Florida
VTA and RCGT
http://www.bearrc.com
pejota is offline   Reply With Quote
Old 08-17-2009, 10:20 AM   #1069
nitrobeast's Avatar
Trader Rating: 21 (100%+)
Default tires?
Ive only ran my WGT a few race days so im still getting use to it. This past Saturday i felt the car lacked steering at exit which it never has. When the front tires get really small does it make the foam seem like its getting harder? The front has about 1-2mm of foam on it.
Rui Goncalves
Jackson RC--Horsham RC--Blue Diamond--
Have you checked your droop today?
nitrobeast is offline   Reply With Quote
Old 08-17-2009, 10:22 AM   #1070
V12
V12's Avatar
Thanks guys. From what I heard 2D-CAD is easier to learn than 3D-CAD and 3D isnīt really needed for the car parts. Alibre is 3D from what I saw.
What do you think of this?
V12 is offline   Reply With Quote
Old 08-17-2009, 11:59 AM   #1071
Originally Posted by nitrobeast View Post
Ive only ran my WGT a few race days so im still getting used to it. This past Saturday i felt the car lacked steering at exit which it never has. When the front tires get really small does it make the foam seem like its getting harder? The front has about 1-2mm of foam on it.
Yes. The shore rating of the wheels are very sensitive to the depth of the foam.
Shawn.
Old 08-17-2009, 12:03 PM   #1072
nitrobeast's Avatar
Shawn.
Is there a "magic" number you shouldnt go past?
Rui Goncalves
Old 08-17-2009, 12:04 PM   #1073
2D is easier because of the single dimension. Download the trial, and try it. Works really well for just about anything.
Shawn.
Old 08-17-2009, 12:11 PM   #1074
For asphault I run mine down to about 3-4 mm of foam, then put them away for carpet use if they are not chunked. Then run new ones straight from the package again.
For carpet I run the tires until the wheel looks like a rim with electrical tape around it.
When running smaller diameter tires, I will soften my car up alittle bit to help regain the traction that is lost.
Shawn.
Old 08-17-2009, 12:11 PM   #1075
Moderator
Pro ten Holland's Avatar
1-2mm of foam left? You're practically running on your rims
I went into a run with my modified 235mm pancar on 2mm front foam a few months back. After a minute or so I didn't have any steering left. I wondered what had happened until I inspected the front tires:
I could see the rim on certain places.
I was running on glue and rim rather than rubber
Pro ten Holland is offline   Reply With Quote
Old 08-17-2009, 01:32 PM   #1076
Send a message via Skype™ to slotracer577
I would say not any easier and might be harder if you try to do drawings with several views. The 3d cad systems all use 2d sketches that are extruded, swept, revolved to create a 3d object. then the drawings just show different views of the 3d object. a much better way to go. Now I am a little spoiled since I have been using pro-e for 14 years and SW for 2.
I do ocassionally use 2d acad for layouts of parts for laser cutting, but even then I import a file from 3d cad first. SW can be purchased as a student version for much cheaper than a full seat.
John
slotracer577 is offline   Reply With Quote
Old 08-17-2009, 02:17 PM   #1077
Send a message via AIM to John Stranahan
Nitro Beast- Like pro ten said that magic number is when you see the rim. If you constantly tinker with you camber you will have a nice flat tire when it gets short. With high traction there is nothing faster. With low traction outdoors I tend to run a larger tire. Sometimes a tire will grow a ridge on the inboard side of the sweeper. I use my Dremmel and a sanding drum run at a high angle to rotate the wheel and remove the ridge. It more or less burns or melts the foam off (with no smell) and a rubber band of foam material finally pops off to leave a bevel and a flat tread.
V12-I like this student version of auto cad. It is fully 3-d but you don't have to go there right away. It does expire in a year and is about $150. The files seem to feed the CNC router just fine. My countersinks (My nephew James's countersink) and the extrusion is my first 3-d adventure. I'll see when the prototypes come back. I can't say it is straight forward getting the countersinks in place. What I do now is paste by eye and then adjust the center position using "Properties". I love the properties screen that gives you all the numbers on your object. It has built in calculators to nudge the objects into perfect symmetry or position. The annotation tools are just outstanding. I use them a lot just to check the drawing against the hand made prototype.
Stranahan-RC.com Suspension kits, CRC Factory Parts/Tools (from chassis to Arms), Alloy Steel screws JohnStranahan@aol.com
TeamCRC.com Mikes-HobbyShop.com
Home of the 2010 200 mm Internal Combustion (IC) Sedan Worlds
http://2010ifmar200mmsedanworlds.com
John Stranahan is offline   Reply With Quote
Old 08-17-2009, 04:00 PM   #1078
nitrobeast's Avatar
Default tires
Sounds good guys, thanks
Rui Goncalves
Old 08-17-2009, 05:31 PM   #1079
tallyrc's Avatar
i use A9CAD.. it's free and a simple, recognizable interface.. 2d only, but as someone else mentioned, you only need 2d for carbon parts.. i was using rhino trial for 3d stuff.. i do have a background with autocad so maybe i had a leg up though..
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 08-17-2009, 06:12 PM   #1080
john-
love this thread...have you had a chance to evaluate the ballistic 13.5 or 17.5? thanks keep up the good info.
cookie1 is offline   Reply With Quote
Forum Jump
CRC Battle Axe, GenXPro 10, 1/10th pan, Brushless, Lipo,4c, Road, Oval,TipsandTricks John Stranahan Oval, Larger Scales and More 0 05-25-2008 10:48 AM
Electric 10th scale sell-off (T4 team, Sphere, Transponder, LiPo, Brushless...) floatch R/C Items: For Sale/Trade 27 03-14-2008 03:37 AM
Battle Brushless Sensorless Mamba Max : Trinity N80 VS CM 36 moumerico Electric Off-Road 3 04-12-2007 02:18 PM
Battle of the EPs (On or Off Road)! marzin Singapore R/C Racers 4 09-22-2005 08:27 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
