Old 05-20-2008, 07:15 AM   #1
pH2's Avatar
Send a message via Yahoo to pH2
Default XRAY T2 '008 Shock Assembly Question
When assembling the shocks, there are two small o rings, one thinner one that goes around the base of the shock body and the thicker one on the piston shaft.
Do most of you build your shocks without the o ring that goes on the piston shaft? What difference does this make?
Also are there any advantages to the aluminum shocks?
Xray T2 '008 -- Novak GTB - 17.5 -- Orion 3600 -- Spektrum DX3R [/color][/SIZE]
pH2 is offline   Reply With Quote
Old 05-20-2008, 09:08 PM   #2
Swanny's Avatar
If you left it off your shocks would leak very badly and you would quickly lose all your oil. You need both o-rings.
Alloy shocks would be smoother overall, but I still run the original plastic shocks on my T2. At least in a big crash the plastic shocks just break and are cheap to fix. If I had alloy shocks on my car with the big crash I had earlier this year, I would have completely written off one shock as I ripped one of the plastic shocks on two. Then I would have to buy a replacement pair. Instead I just replaced one plastic shock body and I was going again.
XRay T2'009 - Sanwa MT-4 - Futaba BLS551 - Tekin RS - Trinity 13.5
Swanny is offline   Reply With Quote
XRAY SHOCK OIL QUESTION STLNLST Electric On-Road 1 10-16-2007 01:43 PM
Hyper 7 PBS front assembly question Nickmind Nitro Off-Road 8 06-06-2007 06:01 PM
T1FK05 shock assembly question Iceracer Electric On-Road 4 01-04-2007 08:44 PM
Shock shaft assembly tool forty6 Electric On-Road 2 09-26-2004 12:10 PM
Xtray T1R SHOCK assembly issues atlrcracer Electric On-Road 11 06-09-2004 09:37 PM
SEO by vBSEO 3.5.0
