Old 11-22-2009, 02:18 PM   #1456
jdmcoupe86's Avatar
@Callahan_88:
what width of rims do you use? they seem to be very large. with which body do you use these rims?
thanks
tb-03
tb-03d
tb evo5ms
jdmcoupe86 is offline   Reply With Quote
Old 11-22-2009, 05:21 PM   #1457
Callahan_88's Avatar
This one!
Itīs the new HPI LP32 and LP35 RAYS VOLKRACING RE30 wheels.
6mm offset in front and 9mm in the back.
The bodie is HPI Aero Supra.
http://www.hpiracing.com/products/en/3341/
Go big or go home! :)
Callahan_88 is offline   Reply With Quote
Old 11-23-2009, 02:55 AM   #1458
jdmcoupe86's Avatar
that looks sick man!
that means that in the back you've got 35mm rims + 9mm offset?! Amazing body! Can you post a pic from the front, too?
thanks
tb-03
tb-03d
tb evo5ms
Old 11-23-2009, 05:24 AM   #1459
Old 11-23-2009, 10:27 AM   #1460
Trader Rating: 82 (100%+)
Is that a 200mm body? Anything else needed other than the wheels and tires to use a 200mm body on a TB03?
bigbeej is online now   Reply With Quote
Old 11-23-2009, 03:28 PM   #1461
I have to push the rear suspension arms as mutch forward as possible.
The front body post are allmost the same just a little bit more narrow on the TB-03.
Old 11-24-2009, 12:43 AM   #1462
Hi guys,
is it possible reduce the IDR from 2,438 to a lower ones i.e. 1,80 or something like that?
tnks
Max
mtaddei is offline   Reply With Quote
Old 11-24-2009, 08:53 PM   #1463
Can anyone with a TB03 please tell me what 64p pinion and spur to use with an 8.5T LRP motor? I just need to know how many teeth on both, I can't figure out the whole FDR thing. I am a complete onroad newb and am ready to sell my brand new kit without even getting a motor in it.
Old 11-24-2009, 09:15 PM   #1464
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Originally Posted by mtaddei View Post
Hi guys,
tnks
Max
Not with available parts.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 11-24-2009, 09:23 PM   #1465
96 spur with 37 pinion for a 6.32 FDR. This will be safe for the motor. However make sure your ring and pinions are shimmed really good or you WILL strip the gears in the front and rear.
Jimmy Wright
Old 11-24-2009, 09:36 PM   #1466
Everything is built to the instructions in the manual.. Is 8.5 too much for this car? I have upgraded the front and rear to aluminum diff, aluminum propellor, diff joint, aluminum spur gear mount, etc..
Old 11-25-2009, 03:44 AM   #1467
Ciao Bigbeej,
the problem is with the coupling between the dif and the propeller shaft pinion, if you have on it too much play you will destroy it with any kind of motor, when you are going to assemble it you must first assemble it as per instruction, then check the ammount of play, then if more then 0,20 / 0,25 mm you must add shims until reach the correct play.
Hoping to clear your doubt.
Max
Old 11-25-2009, 12:47 PM   #1468
No the gears will handle it if properly shimmed for the motor in question. The shimming in the manual is for the motor that comes with the kit to insure that it's not too tight and gives you the best run time without over heating the stock motor.
The gears that are in the TB03 are the same as the EVO 5. So Mod motors are not problem as long as the gears are shimmed correctly.
Jimmy Wright
Old 11-25-2009, 01:23 PM   #1469
Should I shim them for zero play or do you want a tiny bit of movement?
Old 11-25-2009, 02:46 PM   #1470
Will this pinion work with the stock 64T 06 module spur gear? Not sure if 0.6m is the same as 06 module.
http://www3.towerhobbies.com/cgi-bin...&I=LXUFK1&P=SM
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
